Question about Frigidaire FEF366 Electric Kitchen Range
I need help with my frigidaire self cleaning confection range it is flashing F1
What do I do to get my range to stop beeping and flashing F1
  • Anonymous Dec 21, 2008
    es100
  • Anonymous Dec 26, 2008
    I had the same problem and finally unplugged the range. I discovered that if I disconnected the "ribbon" connecting the touch pad control panel to the EOC, I could at least use the elements and the outlets on the range.
    I purchased a new EOC and installed it and I find that the F1 ERR code with the beeping comes up again. Does anyone have any other ideas for diagnosing and correcting the problem? Thanks for any help offered.
    BC
  • 750 Answers
Hello traden,
Welcome,
You said, What do I do to get my range to stop beeping and flashing F1
Please send me your complete model number including that number at the end of the model number.
pull open the storage drawer and you will find a sticker down low on one side.
Mean while you may try unplugging the range for 5 minutes and that should reset the system if it is only a glitch!
Waiting for your Complete Model number.
Huuum
Posted on Oct 17, 2008
I turned on my self cleaner oven this morning and it started beeping and flashing F1. The only way I could stop it was to push the cancel button which of course turned it off
Good Morning Monica, thank you for your post!
Based off what you have described your Frigidaire range is providing you with an error code of F1 after you started a self-cleaning. The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the F1 error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Dec 06, 2015 | Frigidaire Kitchen Ranges
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
Usually the F1 feature does not go away unless you replace the electronic/control board.
I wonder what would happen if you set the door lock assembly to where it was before?
Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
The digital controls on my frigidaire stove do not work. It beeps continually and it flashes F1 on the screen. The oven doesn't work but the burners do. I've tried what it says in the manual to...
F-1 is a sub-code for a few different issues. A button could be stuck, oven cavity getting too hot, or the control has a memory failure. Any of those three failures would require a new control. But first, what happened to the range when it first failed? If you unplug it and try again, what happens?
Aug 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Aug 11, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Oven problem
Hello,F1 means the circuit board is defective and you need to replace the control board.
Thanks
May 31, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven will not work displays f1 error code
I have a Frigidaire self cleaning range model PFEF385JHB1. The range is beeping and the display reads F1 locked. I can not find my user's manual. Please help! Nothing is working.
Nov 01, 2008 | Frigidaire Kitchen Ranges
Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
Jul 12, 2008 | Kitchen Ranges
Frigidaire FEF366 Electric Kitchen Range Logo
139 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
