Question about Microsoft Wireless Optical Desktop Comfort Edition
Keyboard problem When trying to type the @ sign into an email address or word document, the only character that appears is the ' sign. I am having to copy and paste the @ sign from the character map as I am unable to type it. I have just had a new hard drive installed and this has only happened since then. I have a Logitect cordless keyboard and have been told it does not need a specil driver, it just uses the standard Windows one. I have looked at the settings in the control panel and the language is set to English (UK). Any suggestions?
  • 905 Answers
You may need a new battery in the keyboard, also if it is dirty on the IR sensors you will have problems
Posted on Oct 09, 2008
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
My email n password dont match, how can I fix it?
The procedure to troubleshoot email account login issues may vary depending upon your email service provider. So, to let us suggest you a specific solution, can you please share with us the name of your email service provider?
In the meanwhile, we recommend you to make sure that all the keys on your keyboard are functioning properly. If one or more keys are jammed or have stuck up, the keys that you hit may not display characters correctly on your login page. Also, make sure that the functional keys like Caps Lock and Nums Lock are On or Off only when required. To make sure that the keys on your keyboard are working fine, you can first try typing your email ID and password on a Notepad or Word Document and see if they come up correctly. If the keyboard is working fine, we suggest you to try typing your email ID and password slowly (if you have not done this already). Also, give special attention to characters like 2 or Z, 0 (zero) or O, 1 or I, 5 or S, 8 or B etc.
If one or more keys on the keyboard have become malfunctional, try logging in to your account through some other device (if you have not done this already) or consider using a different keyboard (if possible).
You can also try onscreen keyboard by press and hold the Windows key and hit the letter R. Type in OSK and hit enter. Try using the onscreen keyboard if the keyboard is not functioning correctly.
GuruAid.com
Jul 17, 2014 | Computers & Internet
Keyboard not functioning
It may be a fault in the keyboard driver or in the keyboard itself. However if the character you need is not available on the keyboard directly it is possible to get any character by using the ASCII char code entry method. First off search the internet for a ASCII character number associating table (for a chart I like best, check here http://michaelgoerz.net/blog/2008/09/ascii-table/ascii.gif) now on this chart you have to use common fonts (IE: Ariel, times new roman, ect.) because some of the TTF fonts do not have all the characters in them available.
Now to practice using the characters, load Notepad and find the character you want to display from the chart (note: the number like 000d and 00h actually means 000 decimal and 00 hexadecimal, only use the number with the "d" after it with this method), on Notepad, after you pick out the character you want to display, press and hold the ALT key, and on your keypad (on most keyboards it is on the right side and resembles a calculator type keypad) while holding the ALT key down enter the number of the character you want to display (do not include the "d", only the number) then release the ALT key and that character should display for you in Notepad. Almost all standard fonts has the regular characters and some has the extended characters, you will have to check to see if the font uses them by trial and error. this method is a long lost forgotten means of putting characters into your documents which does not have keys on a standard keyboard (most standard keyboards only have 101 keys so this is the only way of using all the 255 character available in common fonts).
This is a built in function of all computers that uses Microsoft OS's and even DOS, HDOS, EDOS, (well all the DOS's), and you can use them anywhere you can type anything from your keyboard, (emails, letters, databases, spread sheets, etc.) if you can type from the keyboard to any program you can use these characters in this manner.
I hope this help you out!
Aug 15, 2013 | E-Machines eMachines Desktop PC
How do i set up an email account
MSN boasts its free email service, Hotmail, as the "efficient way to do e-mail."
Indeed, MSN offers several perks such as advanced security protection, email accessibility with your cell phone and one-stop inboxing, or the ability to bring all your email addresses together.
Once you complete the process of setting up an account with MSN, you'll be able to use your new Hotmail email address.
Open up your Internet browser to the MSN "Create your email address" page.
Select the country or region of the world you live in.
Choose the name you would like to appear before the "@hotmail.com" part of the address. Besides letter and numbers, you can also use hyphens, periods and underscores to personalize your email address.
Press "Check Availability" when you have typed in your desired name to make sure it is not already claimed.
Create a password for your account; your password must have six or more characters.
You'll be prompted to type in your desired password twice.
To protect yourself from identity theft and fraud, you should create a strong password for your email account.
Select a security question from the pull-down menu and provide the answer to the question.
In case you forget your password, you'll be able to retrieve that information upon giving the correct answer.
Or, provide another email address that you use; MSN will send your forgotten password to that email address.
Provide your personal information such as your name, birth date, gender, state, zip code and the time zone you live in.
Enter the characters you see on your screen for verification purposes.
Read through Microsoft's service agreement and online privacy statement and click "Accept" when you are done.
Navigate to the "Sign In" page for Hotmail.
Type your user name (name@hotmail.com) and password in the appropriate spaces; click "Sign In."
Now you are ready to use your MSN email address.
Create MSN email account
https://accountservices.passport.net/reg.srf?roid=2&wa=wsignin1.0&rpsnv=11&ct=1281049588&rver=5.5.4177.0&wp=LBI&wreply=http:%2F%2Fwww.msn.com%2F&id=1184&bk=1281049612&cru=http://login.live.com/login.srf%3fwa%3dwsignin1.0%26rpsnv%3d11%26rver%3d5.5.
Apr 11, 2013 | Microsoft Office Professional 2007 Full...
How do I make the @ sign on the Mexican keyboard
You can use Windows Character Map, located in your Windows start menu under Accessories > System Tools to enter characters that may not be supported by your keyboard. Just open the Character Map window and click on the character you wish to use.from the listed options. Press Select to to choose, then Copy to move the character to the clipboard. Return to your document, place your cursor where you wish the character to appear and press Ctrl -V to insert it into your document.
Feb 23, 2011 | Acer Aspire One PC Notebook
Html codes
What type of order form? My advice would be to use Dreamweaver CS3 but heres a basic form with script that could be easily adapted to an order form.
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="1252"%>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
function verify()
// This section just uses a simple regular expression to check the name
// input box. It checks for one or more characters, a space and another
// group of characters.
if (document.forms[0].name.value.search(/^.+\s+.+$/))
alert("Please make sure you have included your name!")
return
if (document.forms[0].howard.selectedIndex == 0 )
alert("Please tell us what you'd like to do to John Howard!")
return
if (document.forms[0].howard.selectedIndex == 1 )
alert("You'd give John Howard a big tongue kiss? You're weird. Extremely weird. Really very, very, very, very weird. As a matter of fact, you're that sick you can't continue unless you select another option!")
return
// This section also uses a regular expression to check the email input box.
// It checks for one or more characters, then it checks for the email @
// signifier, then another group of characters, then a full stop or period (.),
// then for another group of characters.
if (document.forms[0].email.value.search(/^.+@.+\..+$/))
alert("Please include a valid email address!")
return
else
// If the form is correctly filled out you can submit the form to your mail cgi
// by deleting the next line, and uncommenting the following two lines.
alert("You have filled out the form correctly!")
// document.forms[0].submit()
// return
&lt;/SCRIPT&gt;</SPAN>
</PRE>
<HR SIZE=5>
<H1>The form</H1>
<PRE><SPAN>
&lt;FORM METHOD="POST" ACTION="http://www.your.website/cgi-bin/formail.cgi"&gt;
&lt;INPUT TYPE=hidden NAME="subject" VALUE="Submission from form"&gt;
&lt;P&gt;Name&lt;BR&gt;&lt;INPUT TYPE="text" NAME="name" SIZE=40&gt;
&lt;P&gt;What would you like to do to John Howard?&lt;BR&gt;
&lt;SELECT NAME="howard" SIZE=1&gt;
&lt;OPTION VALUE=0&gt;Please select an option!
&lt;OPTION&gt;Give him a big tongue kiss
&lt;OPTION&gt;Stomp on him while I'm wearing football boots
&lt;OPTION&gt;Beat him around the head with a cricket bat
&lt;OPTION&gt;Make him live in a refugee detention centre for five years
&lt;OPTION&gt;Pour petrol on him and set him alight
&lt;OPTION&gt;Perform explorative surgery on him to discover how he lives without a heart
&lt;OPTION&gt;Ask Buffy to stake him
&lt;/SELECT&gt;
&lt;P&gt;Email&lt;BR&gt;&lt;INPUT TYPE="text" NAME="email" SIZE=40&gt;
&lt;P&gt;&lt;SCRIPT LANGUAGE=javascript&gt;document.write("&lt;INPUT TYPE='button' onClick='verify()' VALUE='Test the verification script!'&gt;")&lt;/SCRIPT&gt;&lt;NOSCRIPT&gt;&lt;INPUT TYPE='submit' VALUE='Submit'&gt;&lt;/NOSCRIPT&gt;
&lt;/FORM&gt;
</SPAN></PRE>
<P></P>
<BR>&nbsp;
</PRE>
</body>
</html>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<title>Contact Us</title>
</head>
<body><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body>
<h1><span class="style2">Contact Us </span></h1>
<form action="" method="post" enctype="multipart/form-data" name="MyForm" id="MyForm">
<p class="style2">Title: &nbsp; &nbsp; &nbsp;
<input name="Title" type="text" size="15" maxlength="10">
First Name:
<input name="First Name" type="text" size="25" maxlength="25">
Last Name:
<input name="Last Name" type="text" size="35" maxlength="35">
</p>
<p class="style2">Address:
<input name="Address" type="text" size="35" maxlength="35">
</p>
<p class="style2"> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;
<input name="Address 2" type="text" size="35" maxlength="35">
</p>
<p align="left" class="style2"><span class="style3">Postcode:
<input name="textfield" type="text" size="15" maxlength="15">
</span></p>
<p align="left"><span class="style3">Email</span>:
<input name="textfield" type="text" size="25" maxlength="25">
<span class="style3">Confirm Email:</span>
</p>
<p align="left" class="style2">Contact telephone no. (including area code) </p>
<p align="left" class="style2">Home:
<input name="textfield" type="text" size="20" maxlength="20">
Mobile:
</p>
<p align="left" class="style2">When would the best time to contact you, morning/evening?</p>
<p align="left" class="style2">Comments:</p>
<textarea name="comments" cols="80" rows="15" id="comments"></textarea>
</p>
<p align="center" class="style2">
<input type="submit" name="Submit" value="Submit">
</p>
<input type="submit" name="Clear" value="Clear">
</p>
<p align="center" class="style2">&nbsp;</p>
</form>
<p>&nbsp;</p>
<PRE><PRE><SPAN>
:0) Hope this helps x
May 21, 2008 | Microsoft Office Outlook 2003 for PC
The @ sign on my keyboard won't work!
I don't know if it's gona be helpful, several times I had the same problem. I fixed this problem pressing different combination of keyboard key. I can't figure out exact one. On my laptop I tried combination with ALT key. This time it was my desktop keyboard, I tried every single combination with ALT and nothing... I was so mad I just press Caps Lock+Shift+Ctrl, my keyboard make a sound and guess what it helps @@@@@@@@@@
Mar 25, 2008 | Computers & Internet
The @ sign on my keyboard won't work!!!
Go to control panel on start menu.You may have to click Classic View. Click Regional and Language options. Click middle tab at the top called Languages. Click the Details button. Click Add and select the English UK option from the drop down list. Apply and Ok.
Mar 25, 2008 | Microsoft Wireless Optical Desktop Comfort...
Microsoft Wireless Optical Desktop Comfort Edition Logo
300 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
