Question about Frigidaire FSE748GF Dryer
Dryer when dryer runs seems like drum out of balance, like the drum in scraping metal on metal and clothes seem to get pinched & torn
  • 550 Answers
That is an accurate description
the drum of all dryers is suspended from a combination of
felt pads at the drum ends
nylon glides under the drum
rubber tired thrust rollers.
the rubber tires wear, and the drum shifts, this pinches and wears the felts, then there is enough space to pinch the clothes in the gap
It is a simple enough fix, and well worthwhile, felts glides and rollers are cheap in comparison to new dryers.
Generically all dryers are pretty much the same, so when you go to the parts store, the felts rollers and glides may be labelled whirlpool or kenmore
they will fit exactly, there are very few that fit very many models.
To do the job
  • UNPLUG DRYER
  • If a top mounted lint screen, remove lint screen and 2 screws under lint screen from top of case
  • with a putty knife or other blunt blade release spring clips at front corners of lid, retaining lid to front panel
  • tilt lid up
  • remove 1screw each side 1/3 way down front
  • disconnect door switch wires
  • remove front panel and door
  • pull tensioner to end of its travel against tensioner spring, and unhook belt
    (Note:: position of belt around tensinoer and motor pulleys for reinstall)
  • pull drum out forwards
  • motor, pulleys, support rollers, felts, and glides can now be inspected
good roller
Dryer - 3d57115.jpg bad roller
rollers are in pairs, if one is worn replace both
Inspect felts and nylon glides where fitted, any wear - replace
to replace felts
requirements 2 or more pairs locking pliers(visegrips) hitemp silicone adhesive
  • pull old felt off
  • scrape off old adhesive
  • spread gllue on drum edge
  • secure felt on drum with visegrip
  • pull felt into place, clip with visegrip, pull again clip with visegrips, work around until felt is attached to drum and clipped in place
  • allow glue to set
nylon glides, if fitted replace easily, a central screw, or glue
reassemble in reverse order
Posted on Oct 09, 2008
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer only works when the door is open
  • Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
  • Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
  • Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Apr 22, 2010 | Whirlpool LEW0050P Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
I'm finding pinholes in my clothing.
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Aug 01, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
Black stains sticking to white clothes on washing
Rollers
Rear seal
Front glides
Front seal
Jun 08, 2009 | Washing Machines
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
415 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
