Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mits TV blue Screen
So what exactly was the repair how costly was it?
I fortuneatly bought a 4 yr warranty from Best Buy on my Mits. same thing happened with the blue screen fuzzy white diamond. The geek squad techie showed me the 2 capacitors that go bad on the power board and he ordered them and once they were replaced the TV worked perfect again. I have 2 weeks left on the warranty, so i'm calling them today to get my last free bulb(screen is kinda darkening, kinda) hopefully i can convince the technician. This was one warranty that bad for itself.
if you have any electronic skills you can replace these capacitors yourself, once you get into the guts of your unit.
Good Luck
Posted on Oct 15, 2008
Mits. rear projection tv ws65905 picture has blue color tint
Your blue picture tube is failing. Invest in a new TV. "If" you can find a new set of tubes(you have to replace all 3 red blue and green) they are around $800-1000. Not cost effective. Run the TV into the ground if you want to wait but do not invest any repair money in my opinion.
Jun 01, 2015 | Mitsubishi WS-65905 65" Rear Projection...
Screen only showing top 3rd, in blue and red, the rest is black
This tv have outer forces hitting the tv LCD screen panel itself.The tv LCD screen panel itself it is dead and leaking radiations,that why showing some lines like spikes 3 more colors lines and the rest tv LCD screen panel is black.This tv can't be repair only must have to replace the whole LCD screen panel itself to solved.Not practical because the LCD screen panel are 90% tv functions and 90% of the cost.Replacing the tv LCD screen panel is the same prices as a new tv.Time to buy a new tv and salvages the old tv for it electronics boards for the same model and make for uses if buy the same exact tv or tries to sell it on Ebay.com for refurbish tv electronics boards to earn some money back.
Aug 26, 2011 | Toshiba 32AV555DB 32" HDTV-Ready LCD TV
Phillips 55" rear projection HD ready --power button lights up, but no picture or sound--just a clicking noise. Also, we can no longer adjust the blue convergence. The adjustment screen comes up, but we...
Got our tv in 2004 and we're having the exact same problem. When the blue convergence started going a couple months ago my husband researched the heck out of it and decided it would cost less to just replace the tv with a newer, nicer model rather than repair it. And now, as of last night, we are having the same power issue where the power button goes on, but won't stay on. It just clicks on and off and no sound or picture. Did you ever get yours fixed, or did you end up replacing?
Oct 15, 2010 | Philips 55PP9352 55" Projection Television
I have a sony lcd 55" flat screen. We have blue dots in the center of the screen multiplying every day. What causes this exactly. Is it cost effective to repair ? Could I repair it my self ? I have basic...
model # says its a 42" sounds like a rear projection lcd tv not a flat panel its your light engine sony will replace it free if its less than 5 years old
Feb 03, 2010 | Sony KDF-42WE655 Television
The screen has blue and green tint but no picture
Probably your formatter board took a dump. First call Mitsubushi and ask them if they will cover a chassis rebuild. If yes then call an authorized service center and ask the to send come out and pull it and send to Mits. Mits is covering the cost on these rebuild on the chassis but not labor. The process takes about 6-12 weeks to get completed but will save you about $400.
Jun 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen
try pressing MENU 123 on the mits remote in sequence. then press ENTER on the remote and let it go through the system reset and see if that gets you where you need to go.
Apr 04, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
CONVERGENCE
Replace STK392-570 convergence amp IC's = common repair for a qualified Mits tech.......................T.
Nov 05, 2007 | Mitsubishi WS-65903 65" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
TV Shuts off, Screen Problems
The problem could be the power supply, the flyback trasformer or simply a bad connection. A repair cost for this TV set could run any where from 75 bucks all the way up to 225 or so, depending on the problem. Good Luck
Apr 29, 2007 | Sony KV-32S40 32" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
