Question about Kenmore 33464 / 33465 / 33469 Gas Single Oven
Smoking Kenmore Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
  • 2 more comments
  • Anonymous Nov 25, 2008
    i've cleaned the inside, removed 2 screws and took a cover off the bottom/inside... no spill or debris there, i don't know where the smoke is coming from. i tried running the clean cycle, but there's too much smoke, had to stop.
    any ideas besides "call service"? anyone?
  • tcholt Nov 26, 2008
    i have the same problem. no spills, i cleaned the inside to be sure, i even removed the 2 screws inside on the bottom and took that cover out... nothing under there. i tried the clean option but after a few minutes that smoked too bad also.
    how easy is it to take apart in the back? is a manual easy to find? (i hate sears stuff)
    does any one have any ideas besides 'call a service tech'... really? that's why people go to these sites so we don't have to pay for expensive service calls....
    thanks!
  • Anonymous Apr 05, 2009
    any resolution to this? I have the same problem.
  • Anonymous Mar 19, 2014
    gAS OVEN JUST STARTED SMOKING. THE SMOKE IS COMMING UP FROM BOTTOM OF OVEN. FIRST TIME I HAVE HAD PROBLEM.
  • 750 Answers
Hello oliver909
Welcome,
You said,Smoke is coming out of the back of my gas Kenmore oven. Oven is clean - no spills/debris. Ran clean cycle and broiler did not smoke. Warmer drawer at bottom, so nothing spilled there. Soon as you turn it on, downstairs is full of smoke. Sometimes after preheat goes off, smoke clears and its fine. But I'm afraid to use it because last time I saw a flame inside.
If your afraid to use it, do not hesitate to call service. Nobody wants a fire!
Huuum
Posted on Oct 09, 2008
Bought a house with Technica oven (5-6 yrs old), turned on grill and it smoked badly. All smoke going into room - should it be sucked up into oven vents ?(slots at top of inside oven when door open)....
The grill probably has some type of oil or cleaning agent spilled on to it. the only way i have done it is just burned it off. But I suppose you could pull the burners and wash with soap and warm water. It's much nicer to have a exhaust vent leading out through the range hood to the outside So if you have the time and money it's a relatively easy job to do. Good luck
May 16, 2011 | Ovens
Model SVD48600 door won't open after clean cycle. Fan also locked on. Powered off overnight; no change: "Locked" still displayed
That is a very complicated unit for the average handyman. It has electronic controls and a relay board, sensors and a locking mechanism. First thing I would check is the locking mechanism and the switch on it. Do this first and let me know if you find one of the switches defective or shorted. While there, check the light switch which is bi-functional being used for the light and also to tell the ERC the door is opened or closed.
Jenn-Air self-cleaning ovens have a special setting that allows you to clean the oven without chemicals or scrubbing. The oven heats to a temperature higher than used for cooking. The intense heat burns food spills and other residue off oven's inner surfaces.
Instructions
1. Remove the broiler pan and any utensils to prevent them from being damaged. Take out the oven racks, since the high heat might discolor them.
2. Wet a cleaning cloth or sponge with hot water and detergent. Wash off splatters or spills from areas that won't be affected by the cleaning process, including the oven door liner and the oven's front frame. Wipe up any excess grease or spills on the oven floor.
3. Close the oven door and press the "clean" pad on the unit's touch pad.
4. Enter the amount of cleaning time. For example, two hours is appropriate for a lightly soiled oven, three for average and four for heavily soiled. Cleaning should start immediately. The oven will remain locked during the cycle.
5. To delay cleaning, hit the "stop time" pad and enter the desired stop time. For example, if it is 9 p.m. and you want the oven to clean for three hours starting at 10 p.m., key in the numbers 1,0,0.
6. While the cleaning function operates, use the scouring pads to wash the oven racks and other utensils. Once the cycle ends and the oven unlocks and cools, you can use a damp cloth to pick up any loose or burnt debris inside. Replace the racks, broiler pan and utensils.
Tell us news.
May 09, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Kenmore oven will not turn off
yes sounds like your bake/broiler relay is sticking closed. this could possibly be a $400.00 repair. look in your owners manuel sometimes they give extended warrenties in there. so all you would be responible for is the labor. let me know how it goes.
Jun 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Smoking Oven
soundsas if you have a dirty stove, Id reccommend running through en extended cleaning cycle, it will SMOKE, that s geting rid of any food/grease trapped inside the flue and cabinet of unit
Jan 31, 2009 | Amana Ovens
I have alot of smoke when i use the self cleaning feature
Self cleaning works by 'burning' all of the material it is cleaning.  If you have excessive grease other material in the oven, it will cause the smoking.  Either do the cycle more frequently or remove as much of the goo as possible with a cloth before beginning.  If you have a ventilator to the outside, turn it on and close the door to the kitchen to contain the odor.
Nov 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven smoking
smoke is caused only by fat getting onto an element and should stop after a while, ie when all the fat is burnt off. this is usually a problem with the grill element.
you can get a finjhe mesh grid which fits over the centre vent in the back plate and this should help
Oct 14, 2008 | Ovens
Excess amounts of Smoke coming out when in use
Locate where the smoke is coming from first. Run a dry test with just the stove. Many times excess smoke can be either oven cleaning chemicals burning off, or debris on the elements.
Jul 11, 2008 | Whirlpool AKZ159IX Oven
Kenmore 33464 / 33465 / 33469 Gas Single Oven Logo
905 people viewed this question
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
