If you do not have a user manual for this printer then download one from this site. It should explain which ink cartridges types to buy and how to replace these. There are only two cartridges but based on the size you can buy different.
HP 662 Black Ink Cartridge (~120 pages);
HP 662 Tri-color Ink Cartridge (~100pages);
HP 662XL Black Ink Cartridge (~360 pages);
HP 662XL Tri-color Ink(~330 pages)
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Flashing light signals you that your cartridge ink is empty. Sorry to know you're in trouble with your printer. Here are my suggestions: You have to buy a new genuine cartridge or you can refill ink. Be warned! Refilling ink or using a refilled ink cartridges will not work until the ink cartridge chip or ink monitor is disabled. For instructions on how to disable an ink cartridge chip, please visit [http://www.ehow.com/how_6201242_disable-ink-cartridge-chip.html]
Now you can CURSE the manufacturer of your printer for making your life sucks by making it complicated the things that should be made SIMPLE and EASY. Printer or Cartridge, more or less, cost you the same. Don't you think the printer cartridges should be made simply refillable/usable unless they are broken, and we should be buying only the ink for the cartridges. It is SO ANNOYING, dude! Good luck.
This is a common problem encountered by printer users and is in fact not a bug but considered a feature by manufacturers who build this function into printers to encourage consumers to buy their expensive ink cartridges. To fix this problem I would buy a 3rd party ink cartridge for use when your ink cartridge is empty. This way you can use your scanner when out of ink (be careful printing with 3rd party ink cartridges, many have mangled or destroyed their printers by using non OEM ink).
I own one of these printers and refill cartridges for a living. When you get this problem its best to return the cartridge for another, thats what I do for my customers.
When buying re-manufactured cartridges its best to buy from a local store and ask about there return policy before making your first purchase.
If you are buying from a reputable re-manufacturer then this will be a very rare problem. It happens with genuine HPs too.
BTW this printer uses HP 74 & 75 inks. when buying re-manufactured buy the HP 74xl which gives (according to HP) 750 printers compared to 200 from the HP74. Remanufactured HP75s are fill to HP75xl capacity.
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low
once it reaches a certain level. The sensor can not be reset. If you
refill an ink cartridge that previously reported low ink, it may print
fine, but the sensor will always report low ink. Buying or replacing
ink cartridges with new Dell cartridges will resolve the low ink
message.
Dell discourages ink refills. Refilling ink may lead to print
quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Have you tried Office Max or Staples?
