Question about Onkyo DV-CP702 DVD Player
Onkyo DV0-CP702 Error: Mecha err
Followed service manual instructions and removed tray and put back in. Still get the error even after reset (hold in stop button).
Any suggestions?
SOURCE: DV-C501 MECHA ERROR
That is a great one! I got a good laugh and sure enough it worked like a charm!
Posted on Jul 20, 2007
Benimur
  • 6966 Answers
SOURCE: DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Posted on Aug 19, 2007
  • 4234 Answers
SOURCE: I have an Onkyo DV-CP702
The loading mechanism is out of timing and needs to be rebuilt. This is a fairly strightforward procedure if you have the manual as there is a sequence and alignment procedure for this. No parts are required in most cases. This unit should go to a service station. If you attempt this and are not aligned correctly, it is possible to damage the optics assembly.
Dan
Posted on Jul 02, 2008
  • 70 Answers
SOURCE: displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
Posted on May 07, 2011
  • 1335 Answers
SOURCE: Have lost the remote control
You can get a substitute remote (the original remote is no longer available) at
http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13118717212490&smodel=DVCP702&brand_pn=ONKYO_DVCP702
Let me know if you have any other problems or questions.Please rate this solution. Thanks.
Posted on Jul 28, 2011
Displaying an error message "mecha
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
My onkyo dvd player is reading mechna err
This is usually caused by a broken tooth on one of the cam gears. While relatively inexpensive for the parts, the unit must be rebuilt in the correct order and alignment. This is not a DIY repair. It is possible that the unit is just confused and out of timing. Try unplugging it for 5-10 minutes. Plug it back in and see if it resets. While I doubt it will, it is worth a try. If not, then the unit should be serviced. Figure on $60-$75 for the repair.
Dan
Apr 16, 2010 | Onkyo DV-CP702 DVD Player
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Ricoh Aficio 1035 Copier
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray.
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
I have an Onkyo DV-CP702 and it keeps saying I have a mechanical error. I thought a disc was stuck, so I followed your tips and took off the top and indeed, there were 2 discs stuck. I took them out, but...
Dan
Jul 02, 2008 | Onkyo Televison & Video
Canon ir 5570 - error E000100-0001
Hello prntrfxr,
E000100-0001 is a secondary code to the initial problem. It means verbatum " The power has been turned off and back on again without resetting the error ". So, there was a previous error code that instructed the customer to turn off the main power and turn it back on in an effort to reset the code. Unfortunately this must have been an error code regarding the fusing system. Canon designed the copier to prompt the customer to power the copier off and back on for all error codes, and more often than not the copier can recover to some degree or another. Fuser codes on the other hand WILL NOT reset even though the display says to power off/on . You will need to go into service mode to reset the error. Press "additional functions"......then the numbers 2 and 8 at the same time and then additional functions again. If you have followed these steps properly you will now be in service mode and a different screen. Just follow these instructions. Press copier. Press functions.Press clear.Press err.Press ok. Power off and on . This WILL clear the code. However, if the problem still exists the code will return of course. THAT code is the one we need to troubleshoot! :-)
Apr 17, 2008 | Canon imageRUNNER 5570 Copier
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
Onkyo DV-CP702 will not load any disks!
Look at page 46 of the manual for reset or initialzation.
Nov 17, 2006 | Onkyo DV-CP702 DVD Player
Kvt 815 dvd error
Mecha Error is a Mechanical Error. You can try to do a reset on the unit but in most cases this does not fix the issue but is free to try and sometimes can suprisingly fix these issue. This is pretty much going mean that the unit will need serviced as it can mean the laser is mis-aligned or is no longer working or can even mean something in the mechanics of the unit is jamed. You can go to http://www.kenwoodusa.com/support/simple.aspx?men=1&M2=38&M3=78 to look up a service center or call 1-800-kenwood to have them give you a service center to send the unit to.
Nov 29, 2006 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
DV-C501 MECHA ERROR
I have actually had the same problem multiple number of times now and am going to suggest you a rather "crude sounding" solution!! First, atleast in my case the problem usually occurs when you turn the DVD player off while it still has DVD/CD inside and then turn it back on a little while later. This is how the "solution" works. I just disconnect the player and give it a good shake !! This somehow dislodges the "stuck" disc inside and voila, the player opens up after reconnecting and pressing the open/close button. Sometimes it takes more than one "good shake". Sounds rather severe but works everytime !!
Oct 04, 2006 | Onkyo DV-C501 DVD Player
Onkyo DV-CP702 DVD Player Logo
188 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
