Question about Panasonic DMR-E55 DVD Recorder
Nothing Is Workig
When you plug, Self Check appear on the sceen
  • 98 Answers
This is a normal feature to run thru Self Check to diagnose any issues usually takes about 15 to 30 seconds to go thru process
Posted on Oct 13, 2008
The LCD Touch-Screen not working
Hi-
Chances are you need to reset the settings. check the guides as well for the correct setup.
Hope this helps
Sep 22, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
No fuel, pump is workig & replaced filter
check ur fuel pressure pump may work but there is not enough pressure going out the fuelpump
Apr 20, 2010 | 1991 Plymouth Grand Voyager
Craftsman 16'' chainsaw would not start even applying starting fluidand full choke.
The first thing to check for is spark at the plug. Remove it and reconnect the wire--lay the plug body on the cylinder head or other metal part. Pull the engine through--the spark should be blue and snappy. If nothing, make sure the ignition switch is set to run and try a new clean plug. If still nothing, you need to check the ignition system. Go to: searspartsdirect.com and enter the complete model number of the saw (minus the decimal point). A series of drawings will appear, select the ignition layout. If this is a newer saw, the ignition will be a self-contained module mounted just outside of the flywheel. The first check before buying a new module is to remove the grounding wire that goes to the switch, and try to get spark again. If still nothing, and the pole gap between the module and the flywheel magnets (set with a thin business card for a clearance gauge) appears to be correct, order a new ignition module. Once you get spark, the other major problem is usually the fuel system. Hope this helps!
Apr 17, 2010 | Garden
Blank screen when I turn on my N64
The blank screen is usually caused by a faulty connection.
If you are sure all of your cables and the expansion pack are installed correctly, try removing the pack and blowing on both the expansion bay and the expansion itself to knock any loose dust out.
If that doesn't help, check the expansion pack and then the the bay for damaged or bent pins. Check the game cart as well.
If everything appears undamaged, you may have a broken/defective expansion. See if you can get your money back and then try to find another one from a trustworthy retailer or friend.
Aug 09, 2009 | Nintendo 64 Console
There is no crosshair sight on t.v. at the beginning when you calibrate the sight nothing appears on the sceen. and when i shoot the screen to pick arcade nothing happens
maybe theres something wrong with the device that you are using. Try to check if it works in other games or check it from other consoles. if it doesnt work, then i recommend purchasing another one..
Hope this works :)
Thank you
Aug 08, 2009 | Namco Guncon 2 Gun for PlayStation 2
I can't see the picture because a message appears on the sceen that says: set parental control pin enter a 4-didgit numeric pin and press select. Whe I try to follow the insructions nothing happens. Help
unplug the television, wait ten seconds, plug it back in. If that fails, try hitting 4 0's or 1234, or 4 1's... If that fails, you may need to press a special button on the remote to clear the password, for Toshiba's i believe it is the " recall " button, you must press it 4 times in 5 seconds to clear the password, and then you will be able to set a new pin
May 30, 2009 | Computers & Internet
Our chilled water supply not working, we have water from supply to fridge, nothing from what appears to be 2 solenoids inside rear l/h behind panel onwards. was workig last night, not now
a few possibilities: the valve you mentioned (one side is h20 the other is the ice maker), the switch or actuator up in the dispenser or a blockage like frozen line somewhere it happens easy to the units that have a coil of 1/4 in. line instead of a tank
May 10, 2008 | Refrigerators
TomTom GPS not workig
If the unit is still under warranty, I would have returned it.
No need to fiddle around then...
Apr 12, 2008 | Tomtom ONE GPS Receiver
Panasonic DMR-E55 DVD Recorder Logo
54 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
