Question about Innovage Mini Flip Phone 1510255
Innovage deluxe handheld mini flip phone
''doc''
can't set call-out code...when press call key everthing go back to default setting.
eddiej65@gmail .com
LOOKING FOR A USERS MANUAL
Posted on Nov 17, 2008
How do I clear all information from a LG VX5500 Cell Phone before returning it.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. With the flip open, press the OK key [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Select Revert by pressing OK. A confirmation message is displayed briefly before the phone resets itself.
Steps to Restore Phone
This erases all user data and contact information entered in phone memory.
  6. Press 6 or Restore Phone.
  8. Enter lock code. The default lock code is the last 4 digits of your phone number.
Sep 14, 2011 | LG VX5500 Cell Phone
How do I reset my phone?
http://www.resetcellphone.com/solution/LG/vx5500
Jul 27, 2011 | Skque FOR LG VERIZON VX5500 VX-5500 CELL...
How to put your lg 420 back to factory setting
in the menu under settings/phone settings there should be an option to restore your pone to factory defaults.
Jun 15, 2011 | Cell Phones
I am setting up my Innovage Deluxe Corded Handheld Mini Flip Phone for use with my MagicJack while traveling. 1. I can receive incoming calls fine, just pressing the green phone button to connect and...
First i would say both units are still in good condition as you can still receive calls from them comfortably without any hassles. If you cannot dial out it is probably as a result of the area code or the dial code not being set correctly. The area code helps to determine which location the home phone is situated to enable the calls to be routed through the proper channels to enable connectivity. The dial out code basically does the same as the area code. Both of them are just like address systems to determine where and how the calls are routed. Try setting both codes and see if the calls still dont go.
Hope this solution has been helpful?
May 01, 2011 | Innovage 1502084 Corded Phone
I cannot figure out how to set the calculator to "degree" mode in order to use sin, cos, and tan. Help please!
In Scratchpad, how do I change the default angle settings from radians to degrees?
By default, your handheld's angle settings are in radian mode. If you want the default angle setting to be changed to degrees, please follow these steps:
  • Using a TI-Nspire Family Handheld with Touchpad, press [doc]. Using a TI-Nspire Family Handheld with Clickpad, press [ctrl] [home] while in an open Document or in Scratchpad. Both procedures will take you to the next screen, and the procedures can also be used on any TI-Nspire Family of Desktop Software.
  • Press the [7] key to select the option for 7: Settings and Status c27070ss1.jpg
  • Press the [2] key to choose the option 2: Settings c27070ss2.jpg
  • Press the [1] key to choose 1: General or press the [2] key for 2: Graphs and Geometry, depending upon which default angle settings you are looking to change. c27070ss3.jpg
  • Press [tab] key once to select Angle, next press the [down] on the touchpad or clickpad and select Degree from the list and press [Enter]
  • Press [enter] on "Make Default". When the handheld asks if you want to save the new settings as default for new documents and Scratchpad, press [enter] to accept the changes. c27070ss5.jpg
Choosing "Make Default" will save the settings as your default settings for both scratchpad, and any new documents you create after that point.
Please rate my post!
Cheers,
Sine Wave
Dec 08, 2010 | Texas Instruments TI-Nspire Graphic...
I want to know if the factory setting is oooo
Factory setting nothing but wipeing the Handheld, If you want to wipe the Handheld follow the steps:
1) Go to Options.
2) Select Security option.
3) Select General settings.
4) Press the menu key, you will get the option for wipe Handheld, once you wipe the Handheld your Handheld will go back to Factory setting, No data will be available in the Handheld.
Thank you for using Fixya.
Nov 15, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Innovage Deluxe Handheld Mini Flip Phone Problem
you need to change the two batteries. by any chance do you have the manual for your phone. i need a copy if you can do this for me.
Dec 31, 2008 | Innovage Mini Flip Phone 1510255
INNOVAGE 1604007
Press SET. Press UP to select Set 8 Speech. Press Set again to confirm. Screen will show default setting SPEECH ON. press Up or DOWN to select ON/OFF. Press SET to confirm newetting
Oct 23, 2008 | Innovage 1604007 Corded Phone
this is a corded phone that plugs into your home phone line. This is not a mobile phone.
Feb 05, 2008 | Lands Phones
Lands Phones Logo
258 people viewed this question
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
Kolbrun...
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
