Question about Maytag Washing Machines
How much soap do i use per load in my neptune front load washer
  • 943 Answers
HI as little as possible. start out with a 1/ 4 cup watch the action through the door. if suds is good .that's enough. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
I have a maytage neptune washer mah8700a that displays "suds". It runs several additional rinse cycles before completing the wash. Have switched to tide and run much less soap. Tried an empty load on
Are you using detergent that is rated for HE (high-efficiency) washers? They are manufactured to require less per load and produce fewer suds. Conventional detergents in HE washers will result in over-sudsing.
Dec 22, 2014 | Neptune Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    During the wash cycle the word "suds" began to flash on screen
    you need to cut down on the amount of soap you are adding per wash,run an empty wash to purge any residual soap from the tub,then use less soap there after
    Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
    Why does my Maytag Neptune Washing machine smell like rotten eggs everytime I turned it on? Maytag Neptune MAH7500AWW Serial 70802618ZM
    you have mold built up around the door boot. you need to buy a package of a product called AFRESH (3 tablets in it). follow the directions on the package. use one a month for maintenance on this machine. also, make sure you do one or two hot washes per month to keep the hoses cleaned from build up of soap and or fabric softener. leave the door open a little bit after each load.
    Nov 08, 2009 | Maytag Neptune MAH7500A Front Load Washer
    My Neptune will not rinse all the soap from laundry, have used extra rinse cycle and using less soap.
    are you using he detergent? its a must in this machine also are your close comming out soaking wet ?
    Aug 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Moldy smelling clothes
    First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
    Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
    Jul 01, 2009 | LG WM-0532HW Front Load Washer
    SUDS error on Neptune washer
    It means that there is too much soap in the machine most of the time. Give it time for the suds to go down then try to run it through again. Try using a little less soap later on. Front loaders need less soap than top loaders.
    Nov 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Washing Machines Logo
    23 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
