Question about Cameras
My camera is several years old. I just got a new computer with windows vista. Can I install your software, version 5.2 which says for windows OS? I have a printer that works with the camera, I just need to know if I can download thepictures.
    Problem Solver:
  • 12 Answers
Windows OS usually refers to all versions of windows (95/98/ME/XP/VISTA)
Posted on Oct 09, 2008
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
Driver for Pretec DC-300 Digital Camera for Windows Vista
Try this:
Uninstall the driver (if installed). Next, put in the driver CD and browse to the setup.exe file. Right click and select properties. In the box that opens, select compatibilty tab and select the box next to "runthis program in compatibilty mode for" and select XP SP2. and install the program
Should that not work, uninstall and retry the above process, but select Windows 98 or 2000 this time..Hopefully that will work.
If it still does not work, then unfortunately, you will either have to downgrade to XP (I believe the driver works for XP) or buy a new camera altogether..
Jun 04, 2008 | Pretec CompactCamera Digital Camera
I have a finnish version of Eyewitness encyclopedia of space and the universe, it worked years ago on our old computer but now I can't get it working on our new one.. the installation will not complete,...
What OS does your new computer have? What was your old OS? Unfortunately, install codes do change with OS versions and a program for a much older program will not run on a new OS (esp for Microsoft products). This program (in its English Windows version) was coded to run under Win95-WinXP; it probably can't run under Win7. You can try installing in the compatibility mode (for Windows - right click on the installer and select properties and the compatibility tab). However, this doesn't always work. It isn't a program listed in the Windows Compatibility Center for Vista or Win7 (although the Vista version is confused with its search results - 47 items found becomes 11).
Another option is to install an OS that will run the program as inside a Virtual PC program or as a dual-boot option. (Win7 Pro and Ultimate allows you to install XP mode free (a virtual XP computer after you download and install two programs from Microsoft).) Otherwise you will need a valid licensed copy of the OS you need.
I wish that I could be of more help.
Jul 23, 2010 | Dk Multimedia Eyewitness Encyclopedia of...
New computer, old software.
Get in touch with Husqvarna direct as they have specialist instructors who will be able to troubleshoot these issues.....search for the Contact page on the Husky/Viking website in your country
Aug 02, 2009 | Husqvarna Viking 1
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
When I bought camera I had Windows XP. New computer has Vista.
So you now have Vista, but the software will not load...
If you have Windows Vista (32-bit), click this link and download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1154651&lang=en
If you have Vista 64-bit, use this link. Download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&product=1154651&lang=en
I hope this helps you, don't forget the "FixYa" rating if this solves your questions!
Apr 03, 2009 | HP Photosmart R725 Digital Camera
QuickCam Zoom not working after upgrade to Vista
Just read the most wonder article on how toe fix your quickcam zoom for vista follow these steps
These is from 2007 post so you will have to google for the drivers mentioned. I did and it worked
I have a Logitech Quickcam Zoom and this is how I got it to work:
1. Install QuickCam 32-bit Version: 10.5.0 Build 1096b
It can be found here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=10234
2. When you get to the camera detection part where it asks you to plug in your camera, plug it into a new usb port (if you had it plugged in when you installed Vista) and just press skip.
3. Windows may try and find the driver for it, you can cancel that too.
4. Install the old QuickCam software (Version: 8.4.8 build 1034A)and overwrite anything it asks you to (it will fail to install completely because of the new version, but it will put the files you need into the Logitech program files directory.
The old software is here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=7649
5. Go to the windows orb (former start button), open control panel, go to system, then on the top left of the window click device manager.
6. Find the unknown usb device (hopefully you only have one... otherwise unplug anything else that doesn't work or you haven't updated the driver for yet)
7. Right click and select update driver, choose a location to find the driver, navigate your way to C:\Program Files\Logitech\QuickCamWebInstall\Drivers\WinNew\PRO2
8. Press OK or whatever, and let it install.
9. Enjoy!
Mine didn't even need to reboot and worked with the 10.5 QuickCapture software. Still need to test with Skype and Live Messenger though.
Jan 08, 2009 | Logitech Quickcam USB Zoom Webcam
Windows Vista installation of drivers.
i jus plugged mah concord eyeQ duo 2000 digital camera into mah usb port and it downloaded the drivers for me without usin mah disc on mah vista...
Feb 08, 2008 | Concord Camera Eye-Q Duo 2000 Digital...
Cameras Logo
52 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
