How do you hook up a 500/1 with out useing the rca cables
    Scholar:
  • 92 Answers
It does not have any other connections for audio input. If you have only speaker level you could buy a speaker to line level(RCA) converter although the sound quality is not nearly as good when doing it this way. You connect the speaker lines to one side of the adapter and there will be RCA connections on the other side to plug into the amp.
Posted on Oct 09, 2008
How do I connect roku 2xs to sony trinitron tv
If your Tv does not have the HDMI port you can use the RCA cables. If your Tv does not have the RCA video/audio ports you will need an adapter from Radio Shack for hooking up a video camera to a cable Tv. This adapter will allow you to hook the Roku to the adapter with the RCA cables, then the adapter hooks to the Tv with a cable just like a cable box. This adapter is also a pass through for other devices like a cable box and or another DVD player. Hope this helps FixYa up.
Aug 07, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a RCA HD52W59 but i cant find a hdmi. What do i do?
Used a S-Video cable for video hook up and a RCA component Red,White cable for a audio output hook up.Or used a all in one RCA component cable Yellow,Red,White for a hook up as a simular hook up for traditional VCR hook up before.
May 28, 2011 | RCA HD52W59 HDTV Projection Television
I have a jl audio 500/1. I had the amp professionally installed. The amp played for 2 days and no it has no sound but the power will come on. what could be the problem. I have new rca jacks, 4 guage power...
Go back to where you got it installed and ask them to fix it.
If you don't want to do that I would recommend going to another good car audio shop and getting them to check it out.
You can test it yourself by hooking up an iPod to it using a Headphone to RCA cable.. test at low volume first.
Dec 31, 2010 | Jl Audio 500/1 Car Audio Amplifier
How do I hook up a dvd player?
Hello Andy, Hi!, you can hook up your DVD in 3 ways. 1. using standard RCA cables, 2, using Svideo cables, and 3. using HDMI cables. Depending on your player. I suggest you buy the RCA cable. they are color coded so the yellow goes to the player Video out to the TV video in, red and white cables goes to the Left and Right channel of the player audio out to the TV audio in. thats it.
Dec 21, 2010 | RCA F27242GY 27" TV
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
CT-32SL 13 antenna busted off, how can we hook up
you can use your rca connectors for your cable if your cable box have rca all you need is rca jacks if you don't have a box and all you have is the coax , then you can use a vcr or a dvd with coax input and rca output "hope i explain this right {" tv-----rca's--2---rca jack output vcr ---coax input ---hook up coax CABLE
May 14, 2010 | Panasonic CT-32SL14 32" TV
My Jl Audio 500/1, power light comes on but no power to subs
maybe it dont have enough to push it ,,did you try it before you buy it?
Mar 01, 2010 | Jl Audio 500/1 Car Audio Amplifier
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
On the RCA cd player - how do I record from songs from one tape cassette to another?
Using RCA cables just hook up the RCA cable to where it says "input" to the one doing the recording, and hook up to RCA cable to the one plug where it says"output" on the one thats gonna do the playing. Red cable goes to red, white to white etc.
Jun 29, 2009 | RCA Audio Players & Recorders
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
71 people viewed this question
 Grubhead
Grubhead
