Question about Frigidaire FGF366E Gas Kitchen Range
Door lock light blinking
The door lock indicator light is blinking as some as I plugged in stove. I have pressed clear and such and it won't disengage. It will not allow me the bake or nothing. Also, the door still opens but its saying door locked
Yidd llllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllooooooooooopppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyybbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
Posted on Oct 09, 2008
I am getting ready to sell. How do I clear the settings on the garage door opener buttons?
Hold the first and third buttons for about 30 seconds. It probably won't take that long, but it will make sure that they are cleared. The red LED light will blink rapidly. That is the signal that it is cleared. Just to make sure, try to open or close the garage door that it was programmed to. Congratulations on the new vehical adventure! Hope this helps! Please feel free to ask and questions if needed.
Apr 25, 2011 | 2005 Chrysler Pacifica
My Locked door indicator is on, but the door is not locked
try and press the clear/off key for three to five seconds and see if that clears the lock light.
then with the door open hold in the door switch and press the self clean and set the time and watch to see if the door lock moves to the locked position.if it does then you can press the clear/off key again to reset it.
Dec 22, 2010 | GE Ovens
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
The button on wall which has a little green lite in the center, keeps blinking, but the garage door does open
Press and hold the lock button for 3 seconds to stop the light from blinking. That blinking is the indication that the lock function is on and your remotes will not work.
May 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Electric Range Model Number: FEF365CGBD> The oven door is open and the lock is engaged. The lock light is flashing. I tried disconnecting power (from the main breaker) for about 10 minutes but that...
. If you can push the latch in manually, press the clear button while the button is pressed in. If that doesn't clear it:
Try disconnecting the power at the breaker to reset any electronics that might be at fault. (Make sure there are no little graphics of a lock that appear on your screen. If there are and you can't find the source, the shut down should help.
There is sometimes a separate switch aside from the light switch the is on the front of the stove front or very close to the latch itself. Considering that the oven clean will work, if there is one, it appears that is working in the in position. Look around the latch and the front of the oven for any other switches. Clean it if you find a separate control so that it can pop back out when the door is open.
hold in the door button and push broil until the latch makes a 360 degree
then the door lock should stop flashing and the oven will work again .
Hold the lock button for 3-5 seconds..
if the door was open but the lock are latched. Holding the Clear/Off button had no effect. We unplugged the unit. Then while one person held the oven door light switch button in, another person plugged the unit in. While still holding the light switch button in, the Clear/Off button pressed for 10-15 seconds, at which point "locked" appears in the display. Then, while still holding the light switch button in, pressing and holding the Clear/Off button unlock the unit.
if still the same problem the door assembly is cracked and that needs replacement.you can get required parts
from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 17, 2010 | Kitchen Ranges
Kenmore gas stove makes a buzzing sound
Is the door locked?? Is it an electronic buzzer sound??
hold the CLEAR button for 3 seconds - the door will unlock.
open the door - and press CLEAR for 3 seconds.
Error code may come up.... close and re-open the door.
Are there any indications on the display?
Or is this a mechanical buzzing from underneath? in this case your gas regulator's diaphragm has failed.
If the above reset doesnt wokr (and the sound is electric) your circuit board will need replacement.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 09, 2009 | Kenmore Kitchen Ranges
The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We werent self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try...
Hello kmgtsg,
Welcome
You said, The door on my frigidaire stove model # FEF389WJCC locked and we are unable to get it open. We weren't self cleaning the oven so I'm not sure what happened. Any suggestions how to fix it? We did try turning the breaker off and that didn't help.
Did you leave the breaker off for 5 minutes or just flicked it off and on?
It may be a faulty door Latch
The door latch consist of a micro switch and solenoid. Once the door is closed and the latch handle.
But first try to deactivate the door lock
Oven Lockout
To activate the Oven Lockout feature:
1. Press and hold for 3 seconds
2. After 3 seconds a beep will sound, LOC will appear & "DOOR
LOCKED" will flash in the display. Once the oven door is locked
the "DOOR LOCKED" indicator will stop flashing.
To reactivate normal oven operation:
1. Press and hold for 3 seconds. A beep will sound. LOC will
clear. The "DOOR LOCKED" will continue to flash until the oven
door has completely unlocked
2. The oven is again fully operational.
Let me know if these procedures work for you!!
Huuum,
Please remember to leave a rating!
Oct 14, 2008 | Frigidaire Kitchen Ranges
Pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Jun 09, 2008 | Ovens
Kenmore Elite Electric Range, Display stuck on LOC
I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
Feb 03, 2008 | Kitchen Ranges
Frigidaire FGF366E Gas Kitchen Range Logo
160 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
