Question about Kenmore 62602 Electric Dryer
Fuse Where is the fuse on my dryer??? I push start and lights come on and I hear a click but it just wont start. I have searched everywhere for a diagram or something to help, but I can't find a thing!! Can someone help, PLEASE!!!! my model nu,ber is 110.8586 Thanks!!! Push button all lights go on but dryer will not start. Once a code PH came up? any help?
  • 147 Answers
Your belt is broken, the click that you hear is a centrifugal switch that shunts your start button, so we know the motor is running. Check your belt.
Posted on Oct 22, 2008
My Samsung dryer wont start, it has power but when you push the start button all you hear is a click coming from inside this happens on all settings
Possibly thermal fuse has blown from overheating, or possibly door switch, or broken belt to name a few things it could be.
Aug 27, 2017 | Samsung Dryers
Roper dryer wont start, do it have a reset button
Check the door switch. With the door open, press the button in and the light should go off. If you don't have a light, listen for a click form the switch as you push and release it. If you don't hear a click, you will need to replace the switch. If the switch is good, then problem will be with the thermal fuse located on the rear of the unit.
Sep 28, 2012 | Dryers
My Dryer is a Maytag MGD5570, just under 4 years old. The dryer has power (light is on), but when I push the Start Button, nothing happens. I checked the Thermal Fuse with a continuity tester and it is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Feb 03, 2011 | Maytag Dryers
Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Mar 17, 2010 | Kenmore Dryers
Dryer has power but wont run when i push start button
Problem is either the door switch or the safety thermal, fuse,. Open door and manually push door switch lever to see if you hear a click when depressed. If you do then the problem is the safety fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps. Rick
Mar 09, 2010 | Whirlpool Dryers
The dryer will not start, you can hear timer.
your problem could be : Door switch, Motor, Thermal Fuse, Timer.
I would start with Door switch and Thermal Fuse.
Jan 07, 2010 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Doesn't start
Try this link and see if this helps you diagnose your problem. Please don't hesitate to contact me if you require further assistance.
I hope this helps you isolate your problem. Let me know if you need assistance in locating parts too.
May 28, 2008 | Kenmore 62602 Electric Dryer
one fuse is on the heater housing the other is on the blower housing if you have not removed it the wiring diagram is inside the console
Apr 10, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
297 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
