Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
Solid Purple Light on Plantronics 220
Has been working fine for 2 weeks, now it has a solid purple light, will not turn off or on and will not connect to my phone.
  • Anonymous Dec 30, 2008
    same exact problem...when unplugged from power source, it is a solid blue light with the same symptoms
  • kwashc Jan 12, 2009
    solid blue light with no connection or anything else.
Explorer 230 went into solid blue light the second time I used it. Fixed mine by letting the headset go completely dead and re-charged and it appears to work fine now.
Posted on Jun 07, 2010
Purple indicator light
Can you hear the Hardrive whirring, are there any messages on screen, or is it just dead with a purple light on.
Dec 18, 2012 | Gateway ProfileĀ® 6C (PROFILE6C) PC Desktop
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I need to know the pin outs on the wiring harness for brake light,running light and turn signals.
Orange/white = Switched 12 VDC (tail light)
Red/yellow = Stop light
Solid brown = Right turn signal power/signal
Solid purple = Left turn signnal power/signal
Solid black = Ground
Aug 08, 2010 | 2004 Harley Davidson FLSTC - FLSTCI...
How do i put the plantronics explorer 232 blutooth in pairing mode?
go to the menu on your phone select manage connections turn bluetooth on (on your phone) then you'll see search, listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
Jun 02, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Manual
use this site and put 220 in the search box - your explorer 220 is found and you can download the user guide http://www.plantronics.com/north_america/en_US/support/manuals.jsp;jsessionid=83D442E12D37E83038D66C83670075A9.delta#results
see page 14 for details of the lights
  • Powering on Blue flashes
  • Powering off Red appears and goes off.
  • Charging battery Red solid light.
  • Low battery Red flashes.
  • Pairing mode Blue/red flashes.
  • Missed call Purple flashes. Single press the call control button to cancel.
  • Ringing Purple flashes. Briefly press call control button to answer the call.
  • Press call control button for 2 seconds to reject the call.
Apr 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Needinfo on what wire does what on the Kenwood Excelon DDX7015, on the main harness and the little 3 wire harness near the center,
yellow-constant
red-accessory
if there is a light green,pink,or brown one is is us for brake ,
purple/white -camera or green/white
green/black-left rear- spk-
solid/green-left rear-spk+
purple/black-right rear-spk-
solid/purple right rear spk+
gray/black-right front spk-
solid/gray-right front spk+
white/black-left-front spk-
solid/white-left front spk+
brown or orange if any phone mute
black -ground
pink/white or purple/white or green/white-reverse camera''
Jul 10, 2009 | Kenwood Excelon DDX-7015 Car DVD Player
Dell Bluetooth Wireless Keyboard doesn't work Mouse works fine. I have 2 Dell Inspiron 530's both worked fine for a few months then both got solid Purple status indicator light on keyboard. Instructions...
check the device for a " reset " button, they are usually located on the bottom of the device, if this does not work, you may need to contact dell directly and discuss the problem further.
Jun 21, 2009 | Dell Inspiron 530 Desktop Computer...
PLANTRONICS VHB 300 PURPLE LIGHT
HI
I SOLVED THE PROBLEM
LET THE HEADSET RUN DOWN, THEN PUT IT ON CHARGE,RED CHARGING LIGHT CAME ,CHARGED FOR 2 HOURS, THEN PAIRED TO 6300, WORKING OK.
JOHN
Sep 06, 2008 | Plantronics Explorer 320 Wireless Headset
How to connect motorola skywing
Attn!!! Purple light wont stay on long enough to pair.
DO THIS:press hook button until light remains on solid (mic folded in)fold mic out while light is still solid then pair.
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
871 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
