Question about Sony PlayStation 2 (PS2) Console
Ps2 not sending sound or pictures to monitor
I opened it and cleaned it out, including the laser piece and changed the cables but still nothing. the disc spins when loaded but it does not pull anything up on the monitor. any ideas? i've had this unit for more than three years. all function stopped suddenly yesterday.
  • Sony Master
  • 6,487 Answers
If you already check all the connection and tried this PS2 to a different Tv and still the same there's a big possibility that the Board of this unit is already bad and some of it capacitor are busted, better take it to repair shop and let them check this unit...
Hope that helps...........
Posted on Oct 09, 2008
    Master:
  • 538 Answers
Sounds like it got hit with a static blast...nada at all..sounds like it is time for a replacement..sorry to be bearer of bad news..the board sounds to be fried..you can try the reset, but i bet you already have
  • Sony Master
  • 19,396 Answers
Check the cable first.
  • Ginko
    Ginko Oct 09, 2008
    If you checked the cables already, then probably the problem is related with dirty lens.
    Try first using a lens cleaner kit, like the ones here, if it does not help, then the PS must be taken apart, and lens cleaned manually.
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
No PS2 cd is working in my PS2 what should i do?
Sir,you are dine with your lens...............you should consider seriously changing your ps2 lens.........take it to Sony outlet ask 'em abt it............it would cost you a bit but after that your ps2 will start working perfectly...............just like the new one.................before you go for changing ps2 lens i would recommend you to clean your ps2's lens by any lens cleanning disc or do it your self (you will only need a screw diver for it).........clean the lens by opening your ps2's disc cover and clean it with cotton or any other soft and clean piece of paper.........thank you.........!!!
Sep 22, 2009 | Sony PlayStation 2 (PS2) Console
Playstation 2 slim doesn't boot
try cleaning the laser with a q tip covered in alcohol very very gently
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
Neither my Playstation nor my Playstation 2 will play most of my black bottom discs..it shows the Playstation logo and sound but no picture..most are role playing .like Dragon Warrior 7 or Lunar.please...
How to Clean PS2 laser lens. Older PS2
  • Step 1 Check the lens-cleaning disk. It is important that it is free from dirt or debris. If its dirty, the disk can damage the laser lens on the Playstation 2.
  • Step 2 Press the Playstation 2 open button. Insert the lens-cleaning disk in the tray and close.
  • Step 3 Wait roughly 10 seconds for the disk to read. The brushes on the lens disk will clean the laser.
    New Slim PS2
  • Step 1 Unhook the PS2 from the outlet and the TV. If the power cord has a connection to the outlet, damage can occur.
  • Step 2 Dip a cotton swab into an alcohol bottle. Open the lid of the PS2 with the button.
  • Step 3 Use the cotton swab to rub the lens. Gently brush the laser lens with the cotton swab, covering the entire area.
  • Step 4 Wait about an hour for the laser to dry
  • I had this same issue with my Older style PS2 and I had to take it apart and manually clean the lens. It worked perfectly after that. I was extremely nervous opening up my system, but if it didn't work I was willing to take the chance.
    Here is a link on someone taking a ps2 apart.
    http://www.youtube.com/watch?v=_6AgzkU2C3g
    Mar 07, 2009 | Sony PlayStation 2 (PS2) Console
    PS2 Slim New Lens, Not Spinning
    Hi guys,
    Well, there is 2 switch. one at  the back left of the cd tray and one one the reset /power switch. both sitch have to be close in order for the disk to spin.
    If you try this dont forget to put a disk on the spindle as you will start the laser. this is for your safety. then, if the disk does not spin, then you can try replacing the laser. or at least verify the ribbon cable that is hook to it. if the ribbon cable is not well inside the plug the laser might move but again the disk won t spin.
    it is related to each other, the PS2 seem to verify the laser prior to start the spindle so what ever happend to the laser affect the spindle.
    and then, if you buy a new laser lens, don't forget to remove the soldering bridge. it is a small ball that is use to avoid static while shiping the lens.
    most of the seller will include a small peace of paper with procedure and also there is web site with picture of this soldering bridge.
    I replace some of them, and I have to say that the small plastic lock for the ribbon  cable to the lens has been an issue and the soldering bridge another one.
    but I got most of the PS2 back and running by replacing the laser.
    I hope this will help you.
    Feb 26, 2008 | Sony PlayStation 2 Slimline Console
    Disc wont work
    Hi AdalVI,
    Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
    I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
    1. Disconnect power and turn the case upside down.
    2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
    3. Remove all the screws.
    4. Remove the Warranty sticker to the right edge of the power socket.
    5. Turn the PS2 over to set it right side up.
    6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
    7. Remove the CD tray lid.
    8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
    9. Hook up the power and A/v Cables.
    10. Remove the little white disc from the CD tray lid.
    11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
    12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
    13. Put it back together, and you’re in business.
    If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
    Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
    Disk Error...Grinding sound when i put it in
    I think you will also have trouble with reading Audio CDs. This is s sign that your Laser is dirty. The following procedure is for the older Big PS2. It will not work for the Slim PS2 model. Do not ever use Alcohol on the Slim models Laser Lens.
    Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
    Lens Problem
    The ps2 is Slim? it often when the ribbon cable of laser lens have lift up more than laser lens. you need replacement with new ribbon If you are inclined to open the system and it is out of warrenty you can do so. or you may consoder sending it back to Sony for repair. hope this helps.
    Nov 05, 2007 | Sony PlayStation 2 (PS2) Console
    My PS2 will not play PS2 games, but it will play PS1 games
    Hi
    If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
    4. REmove the Warranty sticker to the right edge of the power socket.
    6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
    7. Remove the Cd tray lid.
    8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
    10. REmove the little white disc from the Cd tray lid.
    13. Put it back together, and your in business.
    If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
    Nov 04, 2007 | Sony PlayStation 2 (PS2) Console
    About my ps2.
    Hi Jzone,
    Oct 22, 2007 | Sony PlayStation 2 (PS2) Console
    Sony PlayStation 2 (PS2) Console Logo
    29 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
