Question about ASUS P5NSLI (0610839134670) Motherboard
MotherBoard Problem when I turn on my computer appears the icon safetly remove hardware and there is my hard disk and rom but i have istalled all drivers.pls help me =(=(
  • 905 Answers
This means you can safely remove some hardware device like something plugged into the USB port.
but to safely remove the hardware deviceyou haeto right c
Posted on Oct 09, 2008
  • jason Oct 09, 2008
    sorry my keyboard has a bad connection, had to fix it
    but if you right click on it the devices you can safely remove will be listed , just click on the device that you want to safely remove , like when you want to disconnect it or if shutting the computer down
Video issue macbookpro 2006
startup and regular sound White screen appears but no apple logo appear ,
1) smc have been reset multiple times. possible motherboard video hardware issue cause over heating.
2) hold option key switch on laptop it will be see hard disk or DVD drive (apple disk inside) icon, the motherboard good if icon appeared. and the motherboard video dead if not appear. hope to help a little
Jan 02, 2014 | Apple MacBook Pro with 17" Display
Tip
Same problem here.........clicks n all...... After smacking the external hard...
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the experiences is the same as a DEAD Hardisk. Anyways, as I read that sometimes this happens as a result of a hit, well, I wacked my HD as a last hope for it to recover its "memory" (as in the movies) and believe me or not, it worked! I don't know if this might help yours, but it saved mine!
The way I did it was like this: I started the pc and when the HD started to run and I heard a couple of clicks, I hit it against the table while in vertical position (assuming that the arm of the HD might slightly move better that way) one time, and then when the spinning and the first click was heard agin I hit again. After that I heard the typical searching sound of a HD, and you can imagine I started to pray that what I heard wasn't my anxiety sound (if it has any). Now I am a firm believer in the old trick of whacking the old TV to get the vital signal back!
Good luck to you too!
on May 29, 2009 | Western Digital 250GB MyBook External USB...
When i connect my wd 500 gb external hard disk to my pc windows notifies me with an error reporting "problem occurred during hardware installation.your new hardware might not work...
  1. Restart the computer in Safe Mode.
  2. Rename the Driver.cab file that is in the following folder:
    C:\Windows\Driver cache\i386
    For example, rename the Driver.cab file as
    Driver.old.
  3. Insert the Windows XP CD-ROM into the CD-ROM or DVD-ROM drive.
  4. When the Welcome screen appears, click
    Perform additional tasks.
  5. Click Browse this CD, and then double-click the I386 folder.
  6. Click the Driver.cab file, and then on the
    Edit menu, click Copy.
  7. In Windows Explorer, open the following folder: C:\Windows\Driver cache\I386
  8. On the Edit menu, click
    Paste to paste the Driver.cab file in the C:\Windows\Driver cache\I386 folder.
  9. Remove the device that you tried to install.
    For example, if you received the error when you tried to install a printer, follow these steps to remove the printer:
    1. Click Start, click Control Panel, and then click Printers and Other Hardware.
    2. Click Printers and Faxes (or the icon representing the type of device that you want to remove).
    3. Right-click the printer that you want to remove, click
      Delete, and then click Yes to confirm deletion of that printer.
    -or-
    Use Device Manager to remove the device. For example, if you received the error when you tried to install a modem, follow these steps to remove the modem:
    1. Click Start, right-click My Computer, click Manage, and then click Device Manager.
    2. Expand Modems, select your modem, and then press DELETE. Click Yes to confirm.
  10. Restart the computer. Your new device should be detected and automatically installed.
Nov 12, 2017 | Western Digital WD HDD 500GB SATA 25"...
Istalation de mi cam
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Mar 16, 2011 | NGS Technology ShowCam Webcam
I am attached the mother Bord to the moniter but the VGA could no
- remove all pci card. ide or sata cable and all connection from cd rom, hard disk, floppy drive.
- check your ram. ( scrub with rubber and broom your ram slot with brush.( or troubleshut with new one) and then restore to ram slot.
if that problems still appear.
- troubleshut your buildin display with the good display card(new display card)
if that problem is still appear.
- troubleshut your power supply with the new one.
if that problems is still appear.
- troubleshut your processor with the new one but speed of your processor must be same.but if your dont have same speed processor, your can try useing the processor supported by motherboard.
If your was do all the tip but your computer still no display.
i recomended your change to new motherboard support by all your hardware.
hope this tip can help your problems....
Jul 10, 2010 | Intel D845GVSR Motherboard
System Manual
the easiest way to remove your equipment is to look for the icon at the lower right hand next to the volume icon. Go to the mp3 icon left click once and a prompt will appear (safely remove usb mass storage device or it'll have your mp3 players) and you're good too go.
GOOD LUCK =)
May 23, 2009 | GPX MW3837 MP3 Player
Safetly remove hardware doesnt appear in windows tray
Here are some tips for trying to repair, if they don't work there's also a link to free utility that will allow you to safely remove devices:
http://quick.mixnmojo.com/usb-disk-ejector
Feb 01, 2009 | Computers & Internet
INF file textsetup.sif is missing
his behavior may occur if any one of the following conditions is true:
  • Your Windows XP CD-ROM is scratched, smudged, or dirty. Clean the Windows XP CD-ROM with a soft cloth, insert it in the CD-ROM drive, and then click OK.
  • Your CD-ROM drive is not working correctly or the CD-ROM might be vibrating too much for the laser to accurately read the data. For more information about this problem, see your hardware documentation or contact the CD-ROM manufacturer.
  • If you are using multiple CD-ROM drives, your computer may be trying to locate files on the wrong drive. If your hardware has a feature to disable CD-ROM drives that are not being used, disable the CD-ROM drives that you are not using.
  • Your computer is over-clocked. Because over-clocking is very memory-intensive, decoding errors may occur when you extract files from your Windows XP CD-ROM.
  • Try to use the default clock timings for your motherboard and processor. For more information about how to do this, see your hardware documentation or contact the motherboard manufacturer.
  • Your computer has damaged or mismatched random access memory (RAM) or cache memory. For example, you might be using a combination of extended data out (EDO) and non-EDO RAM, or different RAM speeds.
    Decoding errors may occur even if Windows appears to be running correctly. These errors occur because of the additional stress that is put on your computer when Windows tries to extract files and to access the hard disk.
    To determine how to make your computer cache memory unavailable while you are running the Setup program, see your hardware documentation or contact your hardware manufacturer.
  • Ultra direct memory access (DMA) is turned on in your computer's CMOS settings, and the data is moving too quickly.
  • Change from DMA mode to Processor Input/Output (PIO) mode to lower your data transfer rate. If this does not resolve the problem, lower your PIO mode settings. The higher your PIO mode settings are, the faster your data transfer is.
  • You are using a third-party memory manager.
  • There is a virus on your computer.
If you continue to receive this error message, copy the i386 folder from the CD-ROM drive to your local hard disk, and then try to run the Setup program from your hard disk.
Dec 15, 2008 | Microsoft Computers & Internet
No cd-rom icon appears
install a mp3 player /take i tt o
Feb 09, 2008 | Computers & Internet
ASUS P5NSLI (0610839134670) Motherboard Logo
73 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
