Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Ice machine gets too much water. what do i repair?is it easy?
  • 61 Answers
Sounds like a sticky solinoid valve . sometime there is to much water presure in some home witch can cause this problem . chck the water presure is around 50 to 70 lbs . this may cure the problem . excesive presure can actualy hold the inlet valve open.. i hope this helps
please post feadback
Posted on Oct 20, 2008
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
Icemaker not making ice. Green LED is ON, no
you have a dual water valve that sends water to the ice maker and the water in the door and it is very common for the ice maker side or the water side of the valve to go bad and on of them working properly and the other not
Apr 09, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not fill with water and will not make ice .
you have a bad water valve easy repair located in back left of fridge
pull fridge out slowly see if you have enough line
Apr 17, 2009 | Refrigerators
Ice maker not working
Follow the water line. You will find a control valve like a washing machine has. It's easy to check out and replace.
Apr 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dripping from water shute just above ice maker;
Yes the water valve is not sealing correctly and if left untreated can cause issues with freezing up the pipe work and causing water to run down the back of the machine. the poor seal could be caused by grit or limescale getting trapped . it is very easy to change for someone who is diy minded.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Broken Ice Machine
check the fill cup on the back of the ice maker if it is full of ice then thaw it out, if it has ice in the fill cup no water can get into the ice maker cavity
Apr 09, 2008 | Refrigerators
Ice maker is not functioning
sounds like a frozen fill tube, easy to check pull out refrig and you see plstic tub running into top of freezer section from behind, sometimes theres a connector fitting half way up the tube, if not you have to cut tubing and install a coupling to repair cut(available at any harware store)after cutiin tube try blowin throughin to freezer, if you cant its frozen,un freezing somtimes challange, sometimes able to blow straight though the ice other timesi se hair dryer (from iside freezer where fills the ice maker itself. best way ive found is using my steam machine i bought from one of the infomercial.good luck!!!
Jan 01, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
