Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Problems at start
My TV has worked great for 7 years. Now it whistles and different colored lines are scrambled on the screen and volumn doesn't work for about 1-2 minutes then picture clears up but the whistling stays for quite a while and comes back off and on. Sometimes you start it up and it's fine but we can tell it's getting worse. Picture is still great after its warmed up!!!
Thank you for your help.
Bryan
Brc-716@Comcast.net
    Novelist:
    Champion:
  • 203 Answers
Please email me the model number for the tv so i can better assist you.
Thanks,
Tim Nolan
Experttv@comcast.net
Posted on Oct 10, 2008
What would be wrong when the picture that went scrambled and the sound remains clear; the screen is full but it just colored lines?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 10, 2015 | Televison & Video
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
My LCD tv screen becomes scrambled on half of the screen with input from a different source and has reddish colors.
Likely another board is bad--GET IT IN FOR REPAIR UNDER WARRANTY BEFORE NO WARRANTY SITUATION
Apr 01, 2012 | Televison & Video
COLOR PROBLEMS
Buying a new one certainly is an option. Sounds like one of the diodes on the circuit board went bad. If you want to pursue this I can walk you through it. Hit me back if you want to try this.
May 20, 2017 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Periodic color scrambling - out of focus. Seems as though the different colors separate and get out of focus.
Ur tv is having a convergence problems,it dead.Colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 22, 2011 | Hitachi 50GX30B 50". Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Power up fixed but still have scrambled colors
you will need to test some components at the tuner and check the tuner for any bad solder on it , although the tuner may be going bad testing the components around it may find the problem
Dec 29, 2008 | Polaroid FLM-3732 Television
60P8341 Rear Projection - Remote does not work
Your TV needs the part 313501707611 - it's the keyboard that's the cause of your problems - but here's the catch... Philips does not make that part anymore... they say that you need to either find someone to fix the keyboard (which I've had no luck on) or buy a new Television from them... hmm, a $2000.00 TV that needs a $20.00 part now becomes a plant holder in my living room because Philips wants us to purchase a new TV from them.
Oct 06, 2007 | Philips 60P8341 60" Rear Projection...
Tv reacts very slow
the problem is due to the crystal which sets the speed of the processor and it may be dry due to heat if that crystal is replaced or dry soldered the problem can be solved
Jun 27, 2007 | Philips 60P8341 60" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
65 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
