Question about Philips 28PW6006 28" TV
My Philips 28PW6006 28" TV will only turn on for about 5 seconds then back off again ?
When i switch the tv on it comes on with foreign writing on the screen then after about 5 secs just turns back off again ?
  • davieboy1986 Oct 10, 2008
    it says transcado on the screen then it switches off, any ideas ?
  • Philips Master
  • 5,568 Answers
I think the set is trying to tell you something, perhaps concerning the received signal standard. Philips is a global company but TV standards aren't, so it may be letting you know that it cannot sync with the available signal.
If you have, or can borrow a digital camera, take a screen shot while the message is there. Most cameras have sufficient light sensitivity that you can leave the flash turned off since it will just produce glare and possibly obscure the message. You may have to try more than once but if you would like to know what the problem is, I can't think of any other way to capture it.
If you can trap the message, post it back here to this thread and I'll attempt to translate it; I have a fair amount of foreign language familiarity.
Posted on Oct 09, 2008
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
My 36'' Philips tv shuts off after about 5 seconds after I turn it on. The on light stays on but the tv doesn't.
ive had many problems with mu three philips tv and every repair on them was very exspensive they are unfortunately throw aways never buy one again. ive lost thousands..
Jan 28, 2010 | Philips 36PT842H 36" TV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Philips 28PW6006 28" TV Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
