Question about HP PSC 1610 All-In-One InkJet Printer
HP 1610 printer
Photos print fine on plain white paper. Pictures are clear but have faint horizontal lines when using glossy printer paper.
Any solutions?
  • racersax Oct 10, 2008
    Thanks for the help.
    Sax
  • Palmbeach
    Palmbeach May 11, 2010
    This often indicates that your cartridges are low or the nozzles are restricted. If you have new cartridges and still have the problem, you'll probably need to experiment with the quality and paper settings.
    Novelist:
    Scholar:
  • 111 Answers
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Posted on Oct 10, 2008
  • tripwire45 Oct 10, 2008
    Oops. I read too fast. Thought you were talking about photo paper and not glossy paper. Still, you might want to check both sides and see if they're different.
    The other thing that popped into my head after I posted my original comment was that not all paper types are supported by all printers. It's possible that this type of glossy paper wasn't meant to be used with this printer.
    To find out, click the following link and then scroll down to "Paper specifications"
    Product Specifications
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
My printer has problems printing dark colours. When printing pictures or text, it leaves horizontal lines on black only. I have a continuis ink system which has lots of black. Any ideas?
Try changing the print paper type to something other than plain paper. Use the matte paper setting, or the photo glossy. The printer will lay down more ink at these specialty settings.
Jan 24, 2010 | Epson Artisan 800 All-In-One InkJet...
Horizontal lines on pictures
I was using the wrong setting for the print properties. I had it set for "plain paper" - when I re-set for "premium glossy" and altered the quality to "high" - cured the problem and the printer is excellent - every detail. Thanks for your reply
Dec 28, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
Problems with printing photos. Hp Psc 1410
check the configurations again, if the problem were still there, try with other cartridges.
Aug 13, 2009 | HP PSC 1410 All-In-One InkJet Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
HP PSC 1610 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
