Question about Clarion VRX935VD Car DVD Player
Hello please help me
I HAVE A VRX935VD AND WHEN I PUT A DVD OR CD IT SAY FILE READING ,THEN IT TELLS ME ERROR 6 .I THINK IT IS THE LENS .CAN THAT BE THE ERROR 6 . EVERTHING ELSE WORKS FINE ITS JUST WHEN I PUT DVD OR CD PLASE HELP ME...............THANK YOU
  • Anonymous Mar 03, 2009
    same problem
  • Anonymous May 03, 2009
    same as first post but lens cleaning hasnt worked
Your lens is out of adjustment. Cleaning sometimes work. They aren't hard to open and realign...happens over time
Posted on May 01, 2009
  • shortys_k172 Apr 29, 2011
    Try to clean first then if doesn't work send it to repair techs on ebay
I used windows XP on compaq presario 1692 and my laptop is slow & couldn't read dvd .(even vcd)....What can i do? Thx
Hi!
Please format your system and install the OS and drivers accordingly.
Regards,
fossildude
Nov 22, 2010 | Compaq Presario 1692 Notebook
How do i fix my CD player? when i put a disk in, the readout says "err disk" it works every once in a while, but i have run a lens cleaning disk in the player, and it wouldnt even read that disk.
how long have you been using the player? And has it been giving you this type of problem before now?
I think the fault is from the laser (lens) of your player. The lens is very weak such that it cannot read the data or files on a disc, that's why it should disc error, even though it plays some disc but that doesn't mean its not a lens problem.
You need to look for a way to replace the lens for your player so that it can play all discs perfectly well again.
Good luck.
Sep 25, 2010 | XO Vision XO9013 Car DVD Player
My dvd player plays cds but wont play dvds says disc error or unknown disc
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load DVD's. The weak lens is also what's making it says "disc error" or "Unknown disc". It can still play Cd's because, Cd's does not contain large files, unlike DVD's.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all DVD's with no problem at all.
Good luck.
Apr 22, 2010 | LG RC897T DVD Recorder/VCR Combo
Hello my Dell Studio 1435, it can read CD but not reading DVD... it give noise when i put DVD..
Try using a good quality DVD cleaner first. The lens for cd/dvd are different so one may work if the other is dirty. If cleaning does not work then the dvd lens may be out of alignment or broke. With today's prices it is cheaper to replace the drive $30-40 than try to repair it. Hope this helps.
Sep 11, 2009 | Dell Studio 15 Laptop
No File and Disc Error message
clean dvd first with cd cleaner.. before you change optical lens. lens cannot read data on your disc.
Sep 09, 2009 | Televison & Video
A Sony RDR-GX210 DVD player I can play a CD - no problem but when I try a DVD, the TV screen says - ''loading please wait'' and then it drops back to the TV picture witha message - ''Can't play this disc''...
Hi Allan,
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
In your case the lens does not work on DVD , but only on CDs for the reasons above , that is quite common.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Sep 08, 2009 | Sony RDR-GX300 DVD Recorder
Disc error when reading dvd
try to clean dvd plaer lens with a lens cleaner...
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot read
I think your drive is old and full of dust inside or it may be nearing its end. Get some servicing.
Aug 07, 2007 | Toshiba (SD-C2502) Internal DVD Drive
No audio, and error 6
Okay, I'll throw out the "is the disc upside down???" question...
If not, and you are using a regular store bought CD or DVD ( I think I've seen error 6 when using some homemade discs)then maybe the player's lens needs cleaning. There are DVD/CD lens cleaners out there. See if that helps. Maybe pressing the reset button if nothing else helps?
Mar 08, 2007 | Clarion (VRX765VD) Car DVD Player
Clarion VRX935VD Car DVD Player Logo
327 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
