Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Floormate noise Floorscrubber is only 6 mo old. It is making a grinding noise. Sounds like popcorn at times. I don't know why? It still cleans but the noise sounds like it is going to stop at any time.
  • 294 Answers
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
Posted on Mar 01, 2009
Motor making grinding noise and burning smell
A bit too late I fear. There is either grit from an overloaded dust bag in the motor or the brushes have worn out. Spares and not expensive.
Jun 10, 2017 | Hoover H3044 FloorMate Hard Floor Cleaner
I have a Hoover Floormate, Spinscrub 500, I just wanted to know if tis model can also clean carpets.
SORRY , IT'S NOT DESIGNED OR HAS THE ABILITY TO DO ANYTHING OTHER THEN MINOR SPOT CLEANING. TO DO A CARPET , YOU'LL NEED A FULL SIZED UNIT. THE PROBLEM IS THAT NO MATTER WHAT BRAND YOU BUY YOU'LL HAVE PROBLEMS IN LESS THEN 3 MONTHS AS THEY ARE ALL MADE IN CHINA NOW AND THE QUALITY IS TERRIBLE. GOOD LUCK AND WHATEVER YOU DO , DON'T BUY IT FROM KOHL'S , THEY HAVE THE WORST.
Jul 09, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
While cleaning with the floormate the dirty fluid dropt out and it willnot pick up.
sounds to me that something is blocking the suction from the impeller. You might just have to lay down some newspapers and go to town cleaning the unit. Remember it is a machine, and it has to be maintained.
Mar 04, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
I have a hoover floormate h-2800 that does not suck up the water
this is a great vacuum. however it does require an extensive cleaning every now and then. diaassembly is required for this. there is a hose that goes from pick up to the tank. make sure this is clear. also your filter should be clean and dry.
May 20, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Motor runs, but noisey, smells hot, brushes don't turn
First you need to check why the brushes are not turning, this could be due to a lack of suction, which means the smell of heat and excess noise is due to a faulty motor, this can also be tested simply by testing the units suction power.
A faulty motor is the most comon problem when it comes to smells of heat or 'ozone' as well as excessive noise. Good Luck.
Apr 12, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Noise
Hi Linda,
Sounds like clutch problems, try to move the lever for carpet/floor back and forth a few times maybe it will free up. If it still makes the grinding noise, the clutch assembly will have to be replaced. Let me know, i can even walk you through the repair if needed.
Apr 08, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover floormate 500 making super loud noise when
You have a bad motor in the unit. It time for a new machine
May 07, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
My Bissell Cleanview Bagless vacuum makes loud grinding noise.
the ends of the roller have something wrapped around them.see if you can pull the ends off so you clean the caps and bearings
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Floormate stopped sucking up water as well as it used to
Don't know how much dirt has accumulated in the recovery system, but mine was amazing for no more than we use it. The front of the head detaches and you can clearly see where the solution is being vacuumed into. A thin rectangular channel then carries the fluid to a corrugated hose in the back of the head. This channel accumulates a lot of junk too. By removing the recovery tank, you can see where the corrugated tube transfers fluid into another narrow channel which carries it vertically to the top of the recovery tank. The small section of hose seems to be the only thing that stays clean and doesn't limit flow and vacuum. The filter at the top of the tank, which keeps fluid out of the vacuum motor can also get plugged with dirt. Hope this helps.
Aug 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
295 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
