Question about Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV
KDP-51WS550 with 10 red led blinks upon power-up
Does anybody know what to replace to fix this TV? The serice manuals say Q8013,Q8014,R8051, and IC8005. I replaced them already and still the same issue. Can someone tell me what is causing the 10 blinks? I would really appreciate it. The TV works from time to time but mostly doesn't. I would really appreciate it. I have a lot of experience in soldering and repair so I can do just about anything. Please advise.
Thanks
Sal
  • pistonesal Oct 20, 2008
    DO you have the D board and is so how much? call me 727-510-3962
    Thanks
  • Marie Caine
    Marie Caine Oct 31, 2017
    Can someone call me got a flashing redd light... please my#3182689138..thanks
    Problem Solver:
  • 8 Answers
I have a power supply board(g) a audio board and video board and all other boards that im looking to sell they are all good might sell cheap cal me at 573-433-1925
Posted on Oct 19, 2008
  • Jeramie
    Jeramie Feb 13, 2011
    replace ic8004 on bottom side of d board.
I have A 57 inch Sony WegA model #KDP-57WS655 I replaced Q8014 and Q8013 and IC8002 When I turned the TV on R6420 smoked pin 8 IC8002 reads low ohm when in the circuit out of circuit it doesnt read as low....
Hello Angie,
If you had the 10 blinking code before replacing Q8013 and Q8014 then you should have replaced these parts as well
R8051 on D Board and IC8005 might be damaged on D board.
Dec 28, 2017 | Sony Grand WEGA KDP-57WS655 57" Rear...
Part Numbers for Q8013, Q8014, R8051, IC8005
Q8013 & Q8014 are both 2SK3568 sony Part# 6-550-882-01R8051 is 0.1 1/2 watt fusible resistor sony Part # 1-216-837-11 and IC8005 is a TL1431CZ-AP sony Part # 8-759-586-17 you should be able to get those parts through www.tvrepairworld.com
Dec 12, 2012 | Sony KP-57WS520 57" Rear Projection...
Blinking red light 10times
Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Jul 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Apr 12, 2012 | Televison & Video
It will turn on somedays and work great other days nothing red light blinks 10 times
Thats a HV issue which is indicating that there is most likely an issue with the any of the following items all located on the D board. They are:
Transistors Q8013 & Q8014
Resistor R8051
Integrated Circuit IC8005
Aug 31, 2011 | Sony Grand WEGA KDP-51WS655 51" Rear...
Sony 65 inch
Hi
Thanks for using FixYa. Ten blinks on Sony HDTV means-- Check Transistors Q8014 and Q8013 on D- Board for shorts, leakage, or bad solder connections. If the transistors are bad, then also check R8051 and IC8005, these are also on the "D" board.
Please do rate the solution and revert for further assistance.
Thanks Rylee
Sep 18, 2009 | Sony KP-57WS520 57" Rear Projection...
Where can I find Q8014, Q8013, R8051 and IC8005?
where exactly is Q8014 and Q8013? where is board D? How would I know if there are bad? and where exactly is R8051 and IC8005? so I can check and if possible fix it myself. I would really appreciated.
Aug 07, 2009 | Sony Televison & Video
Led 10 blinks then turns off
According to sony,
Thanks.
Jun 16, 2009 | Sony KP-FX532M91 TV
WILL NOT STAY TURN ON
Its bit complicated problem. Service manual states HV Protection as 10 times blinks.
You need to replace D Board or if you know basic electronics and familiar with TV repair, then check followings..
• Q8014 or Q8013 have shorted replace
along with R8051 on D Board
• IC8005 is damaged (D Board
Hope this info will help you out.
Jan 28, 2009 | Sony Grand WEGA KDP-57WS655 57" Rear...
SONY-LED BLINKS 10 TIMES
OK, 10 times is HV protection (High Voltage) and problem can be in D board and Q8013, Q8014 can be shorted along with R8051 open.
also IC8005 can be damaged.
All above parts on D board.
I would recommend to get related service manual for proper diagnose of problem in TV.
Good luck.
Dec 17, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Sony Grand WEGA KDP-65WS550 65" Rear Projection HDTV Logo
447 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
