Head cleaning everytime printer is switched on
I have recently bought a Brother DCP-135C all in one printer, scanner, copier. I am very happy with it apart from, everytime I switch the printer on it goes through the process of cleaning the heads, which is using lots of ink. Is there anyway to prevent the machine from doing this. I have had a look in the manual but can't find anything. It's not possible for me to leave the machine switched on.
  • rave_rockz Oct 22, 2008
    i'm also having that problem...its not even a month yet and my ink is low!!!
    please help...now its very low i'm scared to even switch it on now!!!!!!!
  • Anonymous Mar 31, 2009
    this is really annoying, apart from expensive ink being wasted it takes time to clean up. There must be some way to stop this.
    Scholar:
  • 54 Answers
Hi janebobscott,
Try this, completely remove printer and printer software from your computer. Reboot, use installation cd and reinstall software. Watch very closely the options they give you. It may be you choose to head clean at start up. If your software came with a desktop management utility check this first for options you can change. I hope this helped a little, if not, hit me back, we have other options i.e. software conflicts from previous printer installs.
Thanks for using FixYa.com
Sincerely, cyyyd7
Posted on Oct 09, 2008
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
My printer brother dcp7065dn disply 71 and72 error
This is codes for the ink cartridge. The code means there is a problem with the cartridge. Change them both and restart the machine.
Jan 13, 2015 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Mfc-j630w error messagfe 4f
I don't know but I can't enter into maintenence mode I pressed just as its said but it's won't go and I really need my printer??
Jul 15, 2012 | Brother Multi-Function Center MFC-3360c...
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
HP printer psc 2210 all in one
Chances are that you didn't lock down the scanner when you moved the unit. You can attempt to open the unit and move the scanner bar manually to reset it. HPs are very difficult beasts when it comes to their power up check out. It must be fully functional...including all cartridges...to work in most cases. Good luck.
Dec 20, 2007 | Office Equipment & Supplies
148 people viewed this question
