Question about Motorola Mobility RAZR V3
Razor v3 hey how did you get the battery to touch the 4 pronged thing afterall?? i have some ghetto paperclip contraption pushing the battery downward so it makes the connection but its completely temporary and could fall off at any given moment!! :)  let me know please what to do. thanks mucho.
I took the little screws off the back when you do that it like elevates that whole section so your battery touches. Only take out the two that are like right below the battery and you should be fine.
Posted on Oct 18, 2008
How do you remove electric stove element
Hi goodtimefera,
Follow the steps -
1.Check to make sure the electric element is cool. Place your hand about 6 inches above the element and slowly move it downward checking for heat. If you can lower your hand all the way to the element and it is cool to the touch you can move to step 2. If it is still warm, allow it to cool completely.
2.Locate the outer most ring of the coil and follow it to where it plugs into the stove. The end of the coil has a piece attached to it that is generally a two prong plug.
3.Lift the coil slightly up from the drip pan that it rests on. Pull it straight out from the place where it plugs into the stove. Be careful that you don't bend it up, down or to either side as you are pulling so that you don't ruin the prongs.
4.To return the element to it's receptacle, place the prongs gently back into the receptacle and then firmly push it back into place. Again, be careful not to bend the prongs in any direction as you are pushing the coil into place.
Oct 12, 2009 | Stoves Kitchen Ranges
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
How do i remove my motorola razr v3 br50 battery
take off the back plate, push down on the battery, you should feel it give a little. While pushing down, tilt it back. It should come right out.
Jun 24, 2009 | Motorola Mobility RAZR V3
Phone not turning on
Okay, so i had the same exact problem and heres how i fixed it... first i took off the battery cover exposing the screws holding the speaker/phone charger part on and unscrewed them i took a hair dryer to the phone drying up any water (because it did this to me while i was in the rain and i thought it may be water damage) and the little 4 pronged part that your battery terminal thing touches to and pushed them gently when i put my battery back on the part i took off with the screws pushed the battery up at an angel when i tried turning my phone on it worked fine so i thought the hair dryer must have done it but when i tightened the screws back up the phone turned off... its clearly a connectivity problem with the battery thing (the 4 brass triangle type things) my phone works now but the back is a little loose seeing as how i cant tighten the screws up... its not a complete fix but hey it works right.
Hope this helps,
Sep 07, 2008 | Motorola Mobility RAZR V3
Motorola razor V3m displays "no Service".
You need to take the phone to have the main-board fix to get the service up again.
Jul 04, 2008 | Motorola Mobility RAZR V3
your phone need to be reflash to get rid of the test msg you are receiving take the phone to a mobile service center and have them fix the phone properly for you.
Mar 24, 2008 | Motorola Mobility RAZR V3
HEY, you need to flash t-mobile websession and flex into your phone. let know what software you have on your phone first by pressing *#power at the same time
Jan 15, 2008 | Motorola Mobility RAZR V3
Usb port
yes you are but you may not have done it properly so you should take it to a professional service center or technician and have them do the repair for you.
Aug 23, 2007 | Motorola Mobility RAZR V3
Razor problems :)
May 06, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
