Question about Gateway MX7118 Notebook
Laptop will not power up.
The battery has been getting weaker for some time. When fully charged it will only last about 20 minutes, now my laptop will not power up. When I hit the start button, the button will light up and the disc light will light and it sounds like the hard drive is humming but it only does this for about 10 seconds and everything shuts down. It does not matter if the power cord is plugged in or not or if the battery is even installed, it does the same thing. The laptop worked fine (except for the short battery life), I had been using it, and when I turned it off, it never did start again. Thanks, Mike.
  • aub4768 Oct 25, 2008
    I replaced the battery and now my laptop (Gateway MX7118) will power up with or without the charger but I have no images on my desktop. I can see the backlight is working and a couple of times I have had bars going vertically across the screen but no mouse or anything useful on the screen. Thanks, Mike
    Problem Solver:
  • 35 Answers
You have a bad battery. I had same problem before and i just replace my battery and it works fine again..
Posted on Oct 09, 2008
Basically my samsung n145 netbook wont power up unless its connected to the power supply and also i cant disconnect the power supply when fully charged as it cuts the laptop off straight away :( cheers
Replace your battery to solve this trouble.
Get a battery from a FixYa.com advertiser or anywhere computer batteries are sold.
Thanks for your question @ FixYa.com
Jul 28, 2011 | Samsung N145-JP01US Netbook
Tip
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
    If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
    Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
    Discharge the battery fully and charge few times as the last resort.
    Feb 23, 2011 | Compaq Computers & Internet
    How long do i need to charge the laptop for the first time when i bought it ACER AS5732zg
    Laptop batteries are notorious for dying out and losing charge quickly. If you treat your battery with the utmost care, you'll have success in getting the most out of it. First make sure you charge your laptop battery properly when using it for the first time.
    Most laptops today are equipped with Lithium Ion batteries. It's essential that you learn your model's specifications so you can follow the correct usage practices. This is the only way you'll be able to achieve maximum battery power.
    The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours. When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge (through normal use) to about five percent, and then fully charge it again. Please rate this solution by clicking the thumbs up at the top right of this solution. Your rating is much appreciated. Thanks.
    Nov 02, 2010 | Computers & Internet
    Battery Lifeline
    Have you adjusted your power settings in your control panel? This is the only way to allocate how your laptop is using the battery power. Also, watching a DVD is going to take up a lot more energy then say surfing the internet.
    Mar 03, 2010 | Acer Extensa 5620-4020 Notebook
    Inspiron runs on ac power but not battery
    Sounds like you have a faulty ac adapter or jack on the laptop and its not charging the battery fully. More like a trickle charge. I would recommend leaving the laptop on default power settings or the best power settings and see if their is a differance in life or either shutdown the laptop and let it charge until the light shows fully charged.
    Jul 20, 2009 | Dell Inspiron 1501 Notebook
    My Hp Pavilion Laptop says: 0% available (plugged in, charging)
    Unfortunatelly, not much you can do!
    Most likely it is up to the battery.
    Such things are not unusual. My friends laptop battery died at once (just like yours) in about two weeks after he bought it. Fortunately, it was under warranty and battery was replaced with a new one..
    Normally it takes time the batteries come weaker, but even then, they can keep laptop running for some short time (seconds to minutes).
    The laptop battery is made of a group of batteries, (maybe six or nine) and it is possible that only one of them is completelly dead. That makes a break in the battery circuit, means no other battery can be loaded with power, and that's why you don't have a second of battery power.
    You may try two things:
    First unplug the power and unplug the battery. Check if some dirt, dust or corrosion is on the contacts of the battery or contacts on the laptop.
    If so, carefully try to clean it, and then try to charge.
    Other thing you can try is to go to the shop you bought your laptop (or any other shop) and ask them if they have one on stock, to check if your laptop will work (even for seconds).
    If so, than you have to buy a new battery.
    At the end, please DO NOT OPEN your battery. Nothing you will find inside. Replacement of the batteries inside will NOT WORK !
    Regards.
    Mar 25, 2009 | HP Pavilion dv6000z Notebook
    Dell inspiron 1501 battery won't recharge fully.
    Laptop batteries last 1 to 3 years (check your warranty = most laptop batteries are only 1 year ..) .. anyone who gets 3 years out of one is doing well ...
    Mar 15, 2009 | Dell Computers & Internet
    Open Questions:
    Gateway MX7118 Notebook Logo
    138 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
