Question about Konica Minolta PagePro 1350W Laser Printer
Printing on Card Stock
My machine appears to need more heat to complete fuse the toner to the cardstock. Is there any way to adjust the heat?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 188 Answers
Hi Harold,
Most laser printers automatically adjust not the temperature so much as the speed at which the media travels through the fuser when thicker stock is used.
The important thing here is to make sure that when you are using card stock that you insure that the printer is set for the correct "PAPER TYPE" from the tray you are using.
When the paper type is set to card stock, you should notice that the media will print somewhat slower, thus giving the fuser the ability to achieve the correct fusing temperature through the thicker stock.
Good luck
Posted on Nov 05, 2008
Why is my hp 5610v not printing on cardstock?
Are you print through manual bypass? If not try doing it that way. Card stock is very thick and by using manual bypass it doesn't require as many turns for the card stock.
Apr 26, 2014 | HP Office Equipment & Supplies
Phaser 7400 bypass feeder feeding cardstock much too fast
You need to make sure you set the proper paper type for the tray you are using. (Plain Paper feeds much faster than card stock)
Also recommend you use the bypass tray and open the rear door so the cardstock goes straight out the back of the machine and not delivered to the top.
Nov 09, 2013 | Xerox Phaser 7400DN Laser Printer
I have an oki c9650 when I print on cardstock the blacks become bubbly and flake off, but only when printing on cardstock
Set it or computer, whatever you are using to cardstock, or it may be called thick,there are multiple selections depending on the media. Beacuase thick paper requires slower speed and hotter fuseing.
Sep 26, 2012 | OKI C9650HDN Led Printer
I am trying to print a note card measuring 8 5/8 x 6, with a half fold on the long side. What document size do I choose so it prints when it goes through?
You can adjust the page size in the software application you are creating your document with. By doing this the printer should enable you to print your document. You can also choose to input a customized size. Make sure you choose the cardstock setting so the printer will not cause a paper jam, and it will be able to heat the fuser up enough so the toner will stick to the card stock.
May 28, 2010 | HP LaserJet 4600dn Color Printer
When i copy on cardstock the color comes out flacking with semi-circles in the images.
This is caused by the printer not applying enough heat to the card so the toner cannot fuse correctly.
One solution to this is to select "Card" in paper type on the printer driver and this will slow down the printer and allow the fusing unit to apply more heat.
Also please check what weight card your machine is designed to work with, if your card is over weight !! you will more than likely always have issues with it.
Also some types of card stock have a gloss finish, this can also cause problems with the toner fusing correctly.
Try some lighter weight card if none of the solutions above help.
Dec 04, 2009 | Samsung CLX 3160fn All-In-One Printer
Looking for $500 copier for cardstock printing. What do you recommend?
'Cardstock' is 50lb and up...and I get the impression that you're talking about more than 50lb stock. That machine only runs up to 24lb. I think you may want to research a little more. No machine of that size/price will run "cardstock". That's why I said "good luck"
Sep 03, 2009 | Office Equipment & Supplies
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Looks like toner is not sealed to the paper.
the machine is only designed for 80gsm paper. you can change paper type through printer options in printer manager to card stock. it wil probably not work though as it is really only designed for 80gsm paper. the toner need to be heated to 200oC inorder to fuse to the paper cardstock absorbs less heat than normal paper.
Jan 03, 2009 | Samsung CLP 300 Laser Printer
Printing Business Cards on Cardstock
It could be.
Part of the problem with that machine is that it has to bend the paper to get to the inkjets. If its too think it will stop running.
We use this Avery stock for printing business cards that might be a little thinner cardstock. I would look for some recommended for ink jet printers.
Jun 13, 2008 | HP Officejet 5610 All-In-One InkJet...
Ink smudges when printing cards
If you are using cardstock you have to tell machine that you are using thick paper. Place cardstock in bypass select paper size then select thick 2 or thick 3 as paper type.
This increases trasfer charge ,increases fusing temperature ensuring image is bonded to card stock paper.
No more smudging
Jan 12, 2008 | Toshiba e-Studio 232 Black and White...
Konica Minolta PagePro 1350W Laser Printer Logo
196 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
