Question about VistaSource TSC-750M/BFT VARIANT (8500004011050) PC Notebook
Mouse Frenzy I use a X-750 bf a4tech, I use an USB-hub to connect my mouseand my internet into the only USB-port I have. That didn't work so I got an adapter to use my mouse in the "regular" mouse port, but if I do it takes a couple of minutes after startup and it goes frenzy, by frenzy I mean: It clicks randomly ALL the times, after some thinking I might even believe it clicks at least 20 times/second. It also jumps to random places every time it clicks, but usually down in the corner. This happens every time I move the mouse, even if I only move the mouse with the touchpad. But I'm quite sure it's my x7 mouse who causes it.
    Master:
  • 538 Answers
I suggest you get a usb multi port..those usb to ps2 connectors are dubious at best
Posted on Oct 09, 2008
Team promark keyboard won't work
If it has a USB plug, try attaching it through a different port hub, i.e. not the usb port right next to the one that didn't work. If that doesn't work, test the usb port with something else first. If the USB port is not the problem, you may need to download a driver for the keyboard.
Jan 03, 2012 | Team International Team ProMark Carolina...
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
My Mouse Fails To Work On One Of the USB Ports
I have had several ports go bad for no apparent reason. its happened on internal and external devices.
Frankly, unless this is a thing of principal for you I would just go and order a new hub from Amazon for a few bucks and be done with it. Even if its under warranty you would probably be required to ship the dead one back so that would cost more than getting a new one.
Just my 2 cents
Apr 01, 2017 | Micro Innovations (USB204N) 4-Port
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
How do I insatll my wireless mouse
there is no need of softwere.put batteryin mouse and key board. you should get usb senser with mouseand key bord join it in youy computer usb port . them press mouse and key bort swith then it is automaticaley detaced in your computer.
Oct 28, 2009 | Micro Innovations PD7250LSR Wireless RF...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Mouse wont work
Try a different USB port
Hope i could help
CBZ
Comment if you need more assistance
Apr 28, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
I have an inspiron laptop. the two USB on the side stopped working all of a sudden however when I checked the computer stated that they are working fine
may i know what device was connected to those ports?try connecting a mouse to the same ports and see whether it is detected.If it works well and fine.Other wise goto Control panel>>System>>Device manager>>Universal Serial Bus Controllers>>Here, delete all the USB Root hubs.If you are removing them using a mouse connected,then u might lose the mouse response after u delete the USB Root hubs.Please note this.Restart the system after deleting all the Root hubs and wait for a few seconds for them to get installed back.Restart again and confirm whether the issue is resolved
Mar 15, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
A4Tech R7 problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
if that doesn't work try
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the software program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Dec 31, 2008 | A4tech R7-10 Mouse
R7 doesn't work properly
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Apr 24, 2008 | A4tech R7-10 Mouse
Computers & Internet Logo
79 people viewed this question
Top VistaSource Computers & Internet Experts
David Payne
David Payne
Are you a VistaSource Computer and Internet Expert? Answer questions, earn points and help others
