Question about HP ScanJet 3200C Flatbed Scanner
How to attach outdated hardware cable to computer w/usb ports?
How to attach outdated scanner hardware cable to computer w/usb ports (i.e., remove old unit from compaq and use w/dell desktop usb ports)?
    Scholar:
  • 47 Answers
Hi!
I'm not really sure what you're asking. If your problem is that your scanner has an "outdated" connector and you want to try to connect it to your PC via USB ports, the only sensible answer, given the prices of scanners, is to buy a new scanner. Your old scanner, if it is not USB, is probably a SCSI connector device. Do a Google search exactly like this "USB to SCSI adapter cable" and you'll see a lot of results. Cables generally seem to range from $20 to $100. Even if you get the scanner connected, there is a very high probability that there will not be any drivers available that will work with the new computer and cable. All-in-all, a new scanner, even a cheap one, is the way to go IMO, and will give you better scans to boot.
Good luck and please let me know if this helps!
Bob
Posted on Oct 09, 2008
Canon mx320 error code 21550
Remove both power and usb cables completely then connect them and use the fastest usb port on your computer.
worked for me.
could also mean cables are old and needs replacing
Jan 22, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
I have a hitachi 500gb portable simpledrive and i have already connected both the usb cables to 2 different usb ports and the other end to the drive. it is still not detected. im using an old computer,...
Can you try connecting it to a different computer?
If it still does not work, then you have a "hardware" problem.
Remove the disk-drive from the enclosure, and temporarily attach it as a "slave" disk-drive in a desktop computer, to see if bypassing the USB-to-disk-drive interface will bypass the problem.
Nov 15, 2010 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
My mouse doesnt get detected on my system. please help
Instructions
  1. 1
    Turn off your computer.
  2. 2
    Unplug the power supply, remove your laptop batter, and wait at least 30 minutes before returning the battery and power chord to the laptop. As explained by Trouble Fixers, a cache of data from your USB device is stored on the motherboard. This cache is not completely erased until the motherboard fully discharges following power-down. Once the cache is cleared, most USB errors will be fixed.
  3. 3
    Turn on your laptop computer.
  4. 4
    Try to use the malfunctioning USB port. In most cases, simply turning off and unplugging the laptop will help remedy the problem. If a problem persists, continue with Step 5.
  5. 5
    Click on the "Start Menu."
  6. 6
    Click to open the "Control Panel."
  7. 7
    Click on "System and Maintenance."
  8. 8
    Click on the "Device Manager." A new window will open that lists all hardware and external devices currently installed on your laptop computer.
  9. 9
    Scroll the list until you notice the heading "USB Root Hub." Click on this option.
  10. 10
    Select the USB port that reads "Unknown Device." All other, functioning USB ports should say "unused port" or list a specific external USB device.
  11. 11
    Right-click on the Unknown Device port and then select "Update Driver." According to the tech-help website, Amit Bhawani, this will trigger an automatic update of the USB drivers. If no new drivers are found, the old driver will also refresh and repair. In many cases, a malfunctioning port is simply caused by outdated driver software. With the latest drivers, your port can be used with current USB devices without any problems. If problems do reoccur, then the port may be physically damaged and you'll need to take the laptop computer to a computer repair technician to get a new USB port installed
  12. to forget to leave your comment and testimony
Oct 05, 2010 | Computers & Internet
My PC is not pickup Acer 640P scanner as new hardware
1. uninstall the driver if u have already attempted
2. Disconnect the USB cable from the PC USB Port (the one that is attached to the scanner on the other end)
3. Install the driver for the scanner
4. make sure the power for the scanner is on
4b. When prompted attach the USB cable (the one that is attached to the scanner on the other end) to the PC
5. If it does not find ur scanner then
Do the following:
1. Change the USB cable and try again
If this does not work, get back to me again...
Mar 15, 2010 | AcerScan 620P Flatbed Scanner
I have an HP Scanjet G3010 that I am using with both XP and Vista. The problem is that sometimes it works fine and other times I get an error message that states the following "One of the USB devices...
This is usually caused by a faulty USB handshake. The two most common causes are bad contact (i.e. bad USB port or cable) and interference inside USB hubs, especially the externally powered ones.
You can (usually) solve the problem by disconnecting the cable, waiting for the USB disconnect sound, and reconnecting the cable.
The real solution of course is to correct the hardware problem (which might be as easy as using another USB port, or as difficult as having the scanner replaced -- even if usually the problem is external to the device).
Dec 05, 2009 | HP Office Equipment & Supplies
Computer can't "see" scanner even though plugged into USB port
please check:
if other usb-devices work with your pc, so usb ports of your machine are ok.
try connecting the printer to another machine, using same procedure as u did with the old one
did you get any installation cd with it?
any newer drivers for your win-system available?( inet, manufacturers homepage)
if your system and the printer passed the hardware check, install newer drivers and try again.
wish u luck
Jun 18, 2009 | Ambir Technology DocketPort 485
Identifying correct USB cable for CanoScan FB630U
look at the port on the scanner and look at the cable if they match they should work.
May 24, 2009 | Canon CanoScan FB630U Flatbed Scanner
Problem with USB cable
Have you tried connecting it to another USB port?
Sep 19, 2008 | Dell PowerEdge 2600 Server
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
HP ScanJet 3200C Flatbed Scanner Logo
122 people viewed this question
Ben Johnson
