Question about Euro-Pro Shark GI490 Iron
Power iron will not turn on
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
How do I fix my iron because it is not turning on
1. If there is sign of power (e.g. light is on), the heating element may be broken.
2. If there is no sign of power, check the power point (socket), iron power plug, cable and the power on switch. If everything is fine, you need to get it repaired.
Jun 09, 2014 | Irons
How to stop a flat iron from turning on and off when being used
sounds like a bad connection in the power lead be careful about a possible short hazard ZAP!!! Find a handyman to fix it.
May 16, 2013 | Sedu Pro Ionic Ceramic Tourmaline Flat...
Does not turn on
please see the causes and use the common sense. God bless you
f the iron doesn't heat, make sure power is on to the outlet, check the electrical cord, and check the thermostat (see the Appliance Controls Fix-It Guide) and replace if necessary.
Sep 19, 2012 | Rival IR600 Iron
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
My iron will not turn on....what's wrong?
Welcome to Fixya. If the iron wont turn on it can be caused by a faulty cable, a busted Fuse, transistor, capacitor, switch problem or the main board of system. If you have warranty then you can have it checked an repair for free or if you have knowledge with electronics then you can open the iron and check hte part that is bad
Thanks
Jul 29, 2011 | Rowenta Power Duo Iron
The iron turns itself off while I'm ironing. Whats the problem?
I noticed the same problem my friend. The problem with mine was that the wire was having some kind of partial contact at the end inside the iron. The wire was twisted and tangled. I will advice You to
  1. Unscrew the iron from the compartment at the back of the iron,
  2. Then You force up the control of the iron,
  3. You will see 2 screws side by side, unscrew them open to release the lower part of the iron,
  4. Tail the wire to part that it is connected to in the iron,
  5. Then you unscrew the screws that hold the wire and disconnect it from the iron, then you Cut the rough edge of the wire or you can replace the wire completely,
  6. Reverse the process to reassemble the iron back together.
Also another cause might be that the connection to the power socket is loose and disconnects itself while you are ironing. In that case, it is the socket you are to replace.
Some irons are also made that way, that once it gets too hot and is not being controlled, the power will cut off its power supply by itself.
That should do the job for you. Hope this information was helpful.
Jan 12, 2011 | Braun Irons
Shark iron wont turn on
take it back to were you got it from i think the regulator has just packed up
Jun 20, 2010 | Euro-Pro Shark GI490 Iron
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Euro-Pro Shark GI490 Iron Logo
122 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
