My matsui tv volume is stuck halfway and dont no how to turn it up higher the remote is a matsui 21vin
  • 68 Answers
The tv is in hotel mode which limits the sound try holding the I button on the remote and switch on the tv.
Posted on Oct 09, 2008
Matsui m32lw509
No There is no other way to get into its service mode, without its original remote control. Contact the authorized service centre for Panasonic to buy an original remote control.
Jun 30, 2013 | Televison & Video
Just found original remote control for my matsui tv after trying to use a "universal remote control" to work it. tv requires a 4 digit pin code that i don't know! help.
HI,
Please let e know the make and model no.of your remote.
Also let me know the make and model no. of your TV
I'll let you know the code.
Sep 30, 2008 | Televison & Video
CAMPORT STUCK on???
I had ot go online to buy a remote control to use with my zenith concierge tv. It is the same model # as yours. I ended up paying almost 40 dollars for a remote made by lg who I believe bought out zenith. I believe you could problably just get a universal remote and get the same thing accomplished. I can do everything with the remote I ordered except the one thing I wanted it for and that is to turn up the volume. It says on the menu, custom, not preset, but it still will only go up halfway no matter what I do. I heard that you could program the tv to factory settings but I tried that with another remote and all it did was reprogram the remote so that it didn't work anymore. If you have any suggestions as to how I can get the volume to work on my tv, I would appreciate it as well
Dec 21, 2011 | Zenith B25A02Z TV
How do you reset lamp timer with remote given. I read they said hold volume button and halfway switch. Do you hold volume up button or volume down and what is a halfway switch button? Just replaced lamp...
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
The buttons used are the TV's volume down and the remote's number 0.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Nov 16, 2009 | Panasonic PT-52LCX66 Projection Television
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
My Matsui TV is a fairly old model and it does not have the buttons where you change the volume etc. My remote control has stopped working therefore I cannot turn my TV on. I have bought a universal remote...
matsui tv's are usually clones of another make set so you might be able to trace another remote ..try rs components for an original replacement.try switching on using the station up button...farr64
Apr 29, 2009 | Televison & Video
Unable to programme the matsui to my Pentus TV
With your model number at hand, check the Matsui website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Apr 08, 2009 | RCA 3-Device Universal Remote with...
Matsui tv assistance
Have just read up on this. It seems you have to hold the - volume on the front of the TV at the same time as the no 7 on the remote for 5 secs to reset the PIN number.
Matsui 4in1 remote control instructions
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 14, 2008 | Universal Remote Control DIRECTV Universal...
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
Electro Med Services...
