Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
Kenmore Elite Coldspot 106.56703500 does not dispense crushed iced and automatic dispenser is broken
My Kenmore Elite Colspot (Model # 106.56703500) doesn not dispense crushed ice and the automatic dispenser (the one you can choose in ounces, liters, etc. how much water you want to dispense and it automatically dispenses water for you) feature doesn't work anymore. It does dispense cold water using the traditional button and it does dispense only cubes. The crush button beeps once every time I push it. I also noticed that the automatic dispense button beeps once if I push it. The refrigerator is 2 years old.
Please advise on what should I replace to make all these nice features work again.
Thank you
  • mwnance Mar 10, 2009
    Mine will dispence water but not dispense Ice at all. Occasionaly it will start to dispence ice but stop. It takes a few days to reset.
catriver
  • 878 Answers
SOURCE: Kenmore Side by Side Stainless Refrigerator
Berg, do you have a dispenser lock-out? If so press and hold the lock-out funtion for 5 seconds. See if it comes to life. If this doesn't work you are going to have to do some checks to see if you have power to the disp. board. Check this first..Catriver..post back.
Posted on Dec 18, 2006
  • 172 Answers
SOURCE: Kenmore side-by-side only dispensing crushed ice
Hi blkshop,
Most likely the problem you are having is with the crushed ice solonoid. It is located in the back of the freezer behing the icebucket. The little metal arm from the icebucket goes into a hole, the hole is part of the solonoid. To make sure the problem is with the solonoid, first take the icebucket out and look at the little metal arm on the bottom. When you lift it, it will open for crushed or cubed ice in the bucket dispencer hole. If it works properly then the solonoid is bad.
This repair is sometimes a really hard repair, because it is so hard to get all the stuff out of the way to replace the solonoid. You have to remove the icebucket holder and most likely the icemaker, and on some models you will have to remove the fan and several other pieces to get to it. If you feel like trying the repair let me know, I can ship you the part, I keep almost everyone of those on hand, all I would need is your model and address. My number is (865)945-3808. or my email is mca0824@aol.com . Thanks and I hope this will FixYa. Michael Anderson
Posted on Sep 24, 2008
MNTECH
  • 1543 Answers
SOURCE: PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Posted on Nov 20, 2008
  • 311 Answers
SOURCE: Ice dispenser is stuck in crush mode
Carriage that moves ice bucket rod up is frozen.It's right by the auger drive mote on the left- square hole. Remove bucket and try to free it with your finger. If no luck take hair dryer until you can move it up and down.
Posted on Nov 28, 2008
SOURCE: Model 363-9534753 Kenmore icemaker not dispensing ice cubes
I had the same issue and here's what I did to fix it. I pulled out my ice bin. Pushed the metal rod that's underneath it up. Pushed it back into place so that the metal rod would go above the lever in the hole in the back. Sorry- don't know any of the technical terms or names of parts, but once I readjusted the position of the rod I got ice cubes. Hope it works for you!
Posted on Apr 28, 2009
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
Ice dispenser not dropping ice using dispenser knob
If you can hear the auger motor turn, you may have a large chunk of ice in the hopper.
Jul 25, 2014 | Kenmore Refrigerators
I need the housing for my ice/water dispenser Kenmore Coldspot 106.56926600
Part Number: 8201756
http://www.applianceblog.com/mainforums/sears-kenmore/16912-kenmore-dispenser-housing-broken.html
Jun 11, 2012 | Kenmore Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Kenmore Coldspot Ice dispenser quit dispensing. Model #59592990 makes ice, but the motor in the back will not turn to push out ice or crush it.
the motor could not be receiving power check it's male and female plugs weather they are joined.or the motor needs replacement
May 12, 2010 | Refrigerators
Automatic ice dispenser on Kenmore side by side freezes up
Probably the trap door where ice dispenses out is not sealing tightly causing frost buildup
Sep 29, 2017 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
539 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
