Question about HP Lands Phones
Lost FAX connection - HP Lands Phones
  • 1 more comment
  • john_barakat Oct 09, 2008
    Lost FAX Diagnosisreveals hardwarw problem. Tried all of HP's remmenations. None worked
    Lost FAX connection. Worked perfectly and then lost it. Used all of HP's reommendations. None wrked. Diagnosis FAX hardwarw
    Losr FAX after working ok. Diagnosis on FAX test reveals hadware problem. Used HP recommendation 3 timed. Failure
    Genius:
  • 1,913 Answers
U have to uninstall fax serevice then instal again
go to add remove programs then add remove windows compnentes
but u must have win xp disk.
then alsio try to change cabll.
Posted on Oct 09, 2008
  • kishor khatri
    kishor khatri Oct 09, 2008
    try to reinstall agagin your modem driver of fax.
  • HP Master
  • 1,879 Answers
The unit's diagnostics feature tells you the what exactly the issue is.
other experts recommendation basically is part of HP's recommendation that you already performed.
warranty or service since the FAX part of the printer is integrated and non-user replaceable.
    Scholar:
  • 116 Answers
Uninstall the driver of the fax machine from the pc and reinstall it again with proper instructions comming on to the screen while the software is getting loaded.and change the usb wire when you reinstall it again it is sometimes possible that if the wire gets faulty.and also check that when you connect the wire to the fax machine and the pc, does your pc detects the fax machine and the message prompts on your screen that " new hardware detected" if this message shows on your screen that means its connected and been detected.but if this does not show that means its the problem of either the usb wire or the usb jack where you r connecting the wires.
reply if done or not done.so that we can help you further in this topic.
thanks.
    Sergeant:
    Champion:
  • 200 Answers
Hi
can u explain me clearly so that we can help u..
try to reset the fax and then try it.
It will work
thank you for using fixya..
    Master:
  • 538 Answers
Hmmm..ok...did you try a power reset on the phone..what is the model number of that phone, for review purposes
  • A Womans Computer Man
    A Womans Computer Man Oct 09, 2008
    hmm..this would work best when you let the experts here know the model number..it is essential
    Genius:
  • 3,422 Answers
Can you please describe your problem?
I will be waiting for your reply.
  • Priya darshan Oct 09, 2008
    Please let me know the details of your problem so that i can give you a solution for it.
    Have you tried unplugging the communications cable on both ends and replugging it in?
    Have you tried a different USB port/plug on the computer?
    Have you tried a new/different USB lead?
    When you uninstall the printer/fax did you shut down and then start up again before you re-installed.
    If the 'driver' is corrupted you may need to uninstall this too.
    After
    uninstalling the printer/fax machine , Go to the Printers folder and click on FILE
    >SERVER PROPERTIES> DRIVERS (tab), locate the driver for you
    Lexmark in the list and REMOVE it. Then shut down the computer!
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
How do I get the AM900 fax to work? We lost the book. We hooked it up to the phone line. It rings when the number is called, but it does not connect.
How many rings before it goes back to normal display? There is a possibility that your machine is set to "phone" not fax reception. You can do it right there in the control panel. Look for reception button and select fax, then try again.
Oct 13, 2009 | Sharp FO-DC500 Fax
Hp5500 series fax machine
Plug a regular phone into the wall jack and call a fax nunber, listen for fax tones. You don't have DSL, do you?
May 12, 2008 | HP 640 Inkjet Fax Machine
SET UP
CONNECT POWER CODE TO FAX
ALSO CONNECT TELEPHONE LINE TO ITS POSITION.
THEN RESET YOUR FAX TO DEFAULT SETTINGS
SET AUTO RECEVING .
ALSO IF U HAVE PC WITH MODEM U CAN SEND AND RECEIVE FAX FROM IT.
IF U NEEDD ASK ME.
BYE
Mar 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Electrical Connection
Is it the same as your computer power lead? If so then you can obtain one from any computer store.
Hope this helps you
Thanks J
Jan 08, 2008 | Muratec M2500 Fax
Fax connection
Turn off distinicive ring option (menu 0 something)
plug in direct to phone line on connector marked line, put telephone into docket on fax marked EXT.
Nov 15, 2007 | Brother MFC-3240C All-In-One InkJet...
Lands Phones Logo
Top HP Lands Phones Experts
Are you a HP Lands Phone Expert? Answer questions, earn points and help others
