Question about Dell OptiPlex GX110 PC Desktop
How do I...
Reinstall a copy of the following file? windows 2000 root>system32 toskrnl.exe. Thanks.
    Problem Solver:
  • 5 Answers
It Occurs Due to-• Keyboard issue
• Miscellaneous corruption
• Corrupt boot.ini file.
• Missing boot.ini file.
• Missing or corrupt ntoskrnl.exe file.
• Corrupted hard disk drive or severely corrupted Windows.
Resolution-• At the recovery console command prompt, type the following command, and then press <enter>
• Type expand D:\i386\ntoskrnl.ex_ C:\Windows\system32
• In the above example we are copying these files from the CD-ROM drive letter “D" to local Hard-disk "C". These letters may be different on customer's computer. After files are copied; take out the CD-ROM, type EXIT and press <enter>
• Use BootCfg /rebuild <enter> in Recovery Console to repair Boot.ini
Posted on Apr 26, 2009
    Genius:
  • 1,124 Answers
NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
Keyboard issue
Windows NT installed on a partition bigger then 7.8GB
Solution:
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
In the setup menu, type R to start the repair.
When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
Select the operating system you wish to fix, and then enter the administrator password.
Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the
error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Once at the recovery console type chkdsk /r
Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Posted on Oct 09, 2008
How do I find the adminastrater password if I have forget it?
  1. Boot from Windows PE or Windows RE and access the command prompt.
  2. Find the drive letter of the partition where Windows is installed. In Vista and Windows XP, it is usually C:, in Windows 7, it is D: in most cases because the first partition contains Startup Repair. To find the drive letter, type C: (or D:, respectively) and search for the Windows folder. Note that Windows PE (RE) usually resides on X:.
  3. Type the following command (replace "c:" with the correct drive letter if Windows is not located on C:):
    copy c:\windows\system32\sethc.exe c:\
    This creates a copy of sethc.exe to restore later.
  4. Type this command to replace sethc.exe with cmd.exe:
    copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe
    Reboot your computer and start the Windows installation where you forgot the administrator password.
  5. After you see the logon screen, press the SHIFT key five times.
  6. You should see a command prompt where you can enter the following command to reset the Windows password (see screenshot above):
    net user your_user_name new_password
    If you don't know your user name, just type net user to list the available user names.
  7. You can now log on with the new password.
I recommend that you replace sethc.exe with the copy you stored in the root folder of your system drive in step 3. For this, you have to boot up again with Windows PE or RE because you can't replace system files while the Windows installation is online. Then you have to enter this command:
copy /y c:\sethc.exe c:\windows\system32\sethc.exe
Jan 02, 2013 | Computers & Internet
Tip
How do I fix rundll32.exe on Windows XP?
Rundll32.exe is an important process for the Windows operating system. The process rundll32.exe take the dll file and put their libraries in the system memory. Without this process, the computer should be unstable and very slow.<br /><br />The process runs from your system directory C: \ Windows \ system32. If it executes or runs from elsewhere is most likely a virus or a Trojan. You should scan your computer immediately with a virus scanner. Viruses using the name rundll32.exe are W32.Miroot.Worm. Backdoor.Lastdoor and Trojan.StartPage (among others).<br /><br /><span style="font-weight: bold;">Fix rundll32.exe</span><br /><br />If a virus, such as Netsky, destroys rundll32.exe or, if for any reason, your rundll32.exe is corrupt or is accidentally removed, you must do the following:<br /><br style="font-weight: bold;" /><span style="font-weight: bold;">Find rundll32.exe DC system</span><br /><br />Check if you find a copy of rundll32.exe in the folder C: \ Windows \ system32 \ dllcache or in C: \ Windows \ Service Pack Files \ i386. If yes, go ahead and copy rundll32.exe to the system directory C: \ Windows \ system32<br /><br />If you can not find a copy on your system, try to locate the file on your Windows installation disc. Finally, you just reinstall Windows. It would be time consuming, and you may lose all your data. So what would be the last resort.<br /><br /><span style="font-weight: bold;">First, run a system repair tool to fix rundll32.exe</span><br /><br />There are various tools on the Internet that scan, analyze and fix your computer. In addition to solving your rundll32.exe these tools to remove all registry errors, remove invalid shortcuts and duplicate files, repair DLL files, and remove the errors start-up and running.<br /><br />
on Mar 07, 2011 | Computers & Internet
Windows root system32 ntoskrnl.exe missing or corrupt can you reinstall it without cd?
you can install id using a USB drive.
make your USB drive bootable and then copy the files from any other computer .
Google out on how to make the USB bootbale.
May 19, 2010 | Microsoft Windows XP Professional
How to reinstall <windows
1.Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2.Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3.In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4.Select the operating system you wish to fix, and then enter the administrator password.
5.Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6.You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7.Type exit to reboot the computer.
May 02, 2010 | Dell Inspiron mini 9 - Black , Intel® Atom...
Error message when I turn on laptop-windows could not start because the following was corrupt: windows root)system32 toskrnl.exe- re-install a copt of the above
I'm guessing its Windows XP. You will have to perform a repair install. Boot from the XP CD and select repair install normally takes about half an hour. You will not lose any of your files or programs it will just replace all the windows files. You will however have to install the updates again. If when youre booting from the CD you see an option to delete or format a partition youve done something wrong and gone too far just start again and read carefully.........cheers from Scott
Mar 26, 2010 | Computers & Internet
<windows root>\system32\ntoskrnl.exe.
1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
4. Select the operating system you wish to fix, and then enter the administrator password.
5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
7. Type exit to reboot the computer.
Feb 11, 2010 | ASUS MPM1 (ASS5200) PC Notebook
Boot problem
Better open up ur case [while it is switched off],check the cables of ur HardDisk take them out and put them back again.Then also check ur RAM try pressing it a little into the slot.Solves my problem most of the time.
Jun 01, 2009 | Microsoft Windows XP Home Edition
I have deleted svchost.exe from windows xp
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Dec 02, 2008 | Microsoft Windows XP Home Edition
When i turn on computer black screen says: file missing or corrupt windows 2000 root>\system32\ntoskrnl.exe reinstall a copy of the above file
you need to reinstall the file fom the windows 2000 install disk. if this does not work try restoreing the reg from a backup.
Sep 14, 2008 | Computers & Internet
Dell OptiPlex GX110 PC Desktop Logo
359 people viewed this question
Alun Cox
