Question about IBM ThinkPad T30 2366 Notebook
Think pad T30 - very slow to shut down
How can i fix this , the system takes forever to startup and shutdown
Why does my cpu take so long at start up what an i do to speed it up.not exactly cpu literate..lol....are there some things i an stop from running at start up or i googled thinkpad startup and read that it was norton holding me up.is changing av a good idea what do you suggest please help.even opening programs go slow.bought laptop used
Posted on Jan 19, 2009
    Genius:
  • 1,124 Answers
Your computer needs a clean.
Be sure that your computer is not virus or spyware infected.
Check if the fan is working, another cause could be related to a hardware issue.
Posted on Oct 09, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I have hp pavilion tx 1000 since 3 days it takes 7 minuted to start and takes forever to shut it down so i have to forcefully shut it down please please help me
look up what you have in the startup files, alot of stuf you download puts thier product in the startup and it will take longer for your pc to turn them on and off:
Goto start menu and type in:
MSCONFIG
goto start up and turn off anything that you do not need to run at start up....becareful that you do not turn off key components to your system...just look for software you have downloaded...this will help speed up your start up and shutdown....
Sep 02, 2010 | HP Pavilion TX1000Z Notebook PC
Too many icons on Systray
Most of the icons are related to software you have installed. To shutdown these applications, the easiest way to temporarily turn them off is to run "msconfig". Try doing this as follows...
Press and hold the Windows Logo Key, usually located left of the space bar. While holding this key down, press and immediately release the "R" key. In the box that appears type msconfig and press the enter key or click ok. If you have administrative access, you will see a dialog appear with several tabs across the top. Choose the startup tab and uncheck each application you do not want to run. apply the settings and restart your computer. You can always go back and uncheck choices you want to have run.
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
Computer Shut Down Problem
Is the computer taking forever to shutdown in the blue screen or is it something else. Perhaps try closing the applications running with the system to help the process speed up and actually work without the usage of the power button.
Feb 06, 2010 | Lenovo ThinkPad T400 PC Notebook
Will not shut down. gets to logging off screen and freezes
System unable to shutdown or take a long time to shutdown may be due to windows services not responding properly when the termination command is executed by the Operating System..
System restore usually doesn't help in this kind of situation so uninstall any program that you don't need.and Remove all the programs that loads when the system startup.
You can uninstalled program in the Control panel using Add/Remove Program tools which is very simple.
To remove startup Program,
Click "Start" Buton,
Select "Run"
Type "msconfig"
Click "startup" tab
untick all the programs and reboot the system.
Hope this will fix your problem.
But there's also another instant fix,
Download this software called "Super Fast Shutdown"
Here is the link
http://www.brothersoft.com/d.php?soft_id=28101&url=http%3A%2F%2Fwww.xp-smoker.com%2Fdownloads%2Fsuperfast.exe
Jan 01, 2010 | ASUS Eee PC 900 PC Notebook
How do i shut down my think pad? it will not cut off
In your case,
the most simplest way to shut down your laptop is to override your processing by simply holding down the shutdown button until your computer turns off (do this when all your work is saved and the "Windows is shutting down" mode is on your screen).
This idea is not recommended but will always work.
Hope I helped
- donman92
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
I have Dell inspiron 1420, but my laptop starts & shutdown very slowely
hmm that means there are lot of service is running in your computer...try this for starts-
1)open run command
2)type msconfig in run.
3) uncheck all unnecessary program at startup tab then restart system.
now for shutdown pc
try this
1) open run command
2)type regedit
3) search waitforkill registry using ctrl f.
4) increse value of waitforkill like 200 to 20000.
Mar 29, 2009 | IBM ThinkPad T30 2366 Notebook
Startup/shutdown
Sounds like a failing hard drive.
Have you got an XP or Vista cd around?
Feb 25, 2009 | HP Pavilion TX2510US Notebook
Slow startup slow all together
The first thing I'd try to do is see what programs are running at startup. To do this Click on Start--> Run -->type "msconfig" without the quotes.
Click on the Startup Tab and view all the programs that are running at startup. As for deselecting which programs run at startup you can directly ask me which ones you can disable. For the most part all instant messengers and most program files can be disabled.
DO NOT disable any Windows/system32 files!
Jan 19, 2009 | IBM ThinkPad T30 2366 Notebook
Shut down
The best thing you can do is to reinstall windows. This will surely fix the problem.
Jul 26, 2007 | Acer Veriton 5600G PC Desktop
IBM ThinkPad T30 2366 Notebook Logo
336 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
