Question about Kitchen Ranges
I HAVE RECENTLY BOUGHT A STOVES COOKER AND WHEN I FIRST TURN THE OVEN ON THE IGNITION KEEPS MAKING A NOISE IT DOES EVENTUALLY STOPS BUT DRIVES YOU MAD IN THE MEANTIME I HAVE CHECKED THE RINGS ON THE TOP ANY IDEAS
If its a sparking noise the ignition should stop sparking as soon as there is a flame! give or take a few secs... if it keeps sparking check nothing has fallen in flame area in transit if not its faulty call stove an they will replace ingition assy
Posted on Oct 09, 2008
I have a belling double oven. The bottom is fan assisted. It all works okay but when it is turned off it is making a drumming noise after the fan has stopped. This lasts for at least 5 minutes. Any...
Sounds like the cooling fan bearings are worn, hence the noise after you turn the cooker off.This fan is in the top of the oven and helps to keep the inside cooker electrics cool and often keeps going for a while after you have turned the cooker off. Best to call an engineer to check this out for you!
Nov 30, 2014 | Ovens
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
Jun 10, 2009 | Stoves Ovens
Oven Ignition Keeps Clicking
it is the spark generator at back of cooker they are about £65
Mar 16, 2009 | Cannon Chesterfield C60G Kitchen Range
Ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Feb 11, 2009 | DCS Large Appliances Built-In Ovens...
Stoves genus 900 will not switch on
I have a power supply for one and also a front panel dont know if this helps.
Jan 19, 2009 | Stoves 720EF Electric Double Oven
Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Nov 16, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Stoves df 600 sidom
We had ours fitted by a Stoves engineer who said he had the same cooker. He also told us that sometimes the fan will stay on after you have finished using it. The reason is, there will still be heat coming from the cooker or grill after use. For that reason, the fan stays on for a bit afterwards. Its just a safety precaution so that the knobs dont get too hot.
Jul 11, 2008 | Stoves 600SiDOm Gas Kitchen Range
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Jun 21, 2008 | Stoves Premier 720GRa Gas Double Oven
Kitchen Ranges Logo
135 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
