Question about FIC Samba SM-1845 (SM1845GV) Barebone
Computer won't boot on start
No video at all, fans run, hard drive light comes on steady...on for awhile then out.
I have tried a new video card, new pwr supply, reseated the ram, etc.
No help!!
thanks, Bob
  • Russ Andrews
    Russ Andrews May 11, 2010
    Possible bad video...are there any beep codes when you fire it up?
  • 145 Answers
Sound like you have a bad mother board
Posted on Dec 16, 2008
  • Lawrence Walters Dec 16, 2008
    sound like you have a bad mother board
Motherboard or possibly something less dramatic?
No! you have done everything you can, the motherboard is the issue and the only option is replacement.
Jun 01, 2012 | Dell Inspiron 518 Desktop Computer
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
Card started making loud clicking noise i have tried blowing dust out of it when i start my computer within a few minutes clicking starts again
Hi, couple main reasons to get loud clicking in a computer. First is the hard drive, so if you can turn the system off and disconnect the power and the information cable from the hard drive, yes your computer will not boot all the way back into windows but that is ok since you just want it running for awhile to see if the clicking stops. Next thing would definitely be the fans, any fan in the system, the blade part of the fans can get loose sometimes and start to hit the sides as it spins around, you need to be sure about which part it is that is causing it, it can come from the power supply fan, the case fan, the video card fan, the cpu fan, and you might have more than one case fan, test by disconnecting one at a time just make sure to disconnect the device too so you do not over heat anything. Once you identify which fan just replace it, if its something like power supply or video card, unfortunately you might want to look into either warrantying the part or buying a new one.
Nov 01, 2009 | PNY GeForce 9800 GT, PCI Express Video...
Tecra M3 won't boot, hdd light comes on then off.
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Jul 30, 2009 | Toshiba (K000823110) Motherboard
Computer runs but won't boot
is there a reset button on the power supply. if so try that. you might have accidently disconnected the hard drive cable. unplug AC and check all the connectors around the area where you installed the video card. make sure everthings connected. then before u close the case re connect the AC and check visually if the power is on and if everthings running.
Jul 09, 2009 | Gateway GT5056 PC Desktop
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Trouble booting after cleaning
Try unplugging the dust on the cpu grooves under the cpu fan.
Hope it helps
Nov 22, 2007 | Abit A17 Guru Motherboard
Monitor not Running(shows only orange light)
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Dec 26, 2006 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
FIC Samba SM-1845 (SM1845GV) Barebone Logo
223 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
