Question about Mantis 2-Cycle Tiller
Mantis will not start
My husband thought it was low on the fuel/oil mix so we bought more, mixed it, and it still will not start. A couple days ago when I was using it, the plug to the fuel came undone. There were two holes but I was not sure which it plugged back into, the one directly facing down, or the one facing down and to the side.
I pumped the primer and the oil gas mix came out of the one facing down and to the side, so I plugged it back into that one. I primed it again, and it still would not start. So, I tried the other. Again would not start.
I have never used one before and my husband and I are borrowing it from my father in law.
When I showed my husband he insisted that I originally had it wrong and the directly facing down is where it should be plugged in. I told him that when I primed it, the oil gas mix squirted out of the side one. He still insisted that the air intake was the side one.
So which is it?? Did I cause any damage in switching back and forth while troubleshooting??
Any answer would be helpful. Thanks!
Mantis tiller primer ball will not pump gas. I replaced the old one and it still does not pump fuel. when Ipump the ball Iget pressure in one line but no sucttion into the carb.
Posted on Oct 12, 2008
Do you have to mix oil and fuel before putting in the fuel tank if so what oil and petrol do i need to use
Yes. You need to purchase two-cycle oil and mix it with petrol according to the chainsaw manufacturer instructions (this information is in the manual). It will specify the appropriate mix for your chainsaw.
Apr 23, 2015 | Garden
Brand new mantis motor/started when i got it let set for a couple months wont run it will start on choke
The first thing I would do would be to dump out all of the old gasoline mix from the tank and replace it with fresh gasoline mixed with the proper amount of 2-cycle oil.
Jul 21, 2014 | Mantis 2-Cycle Tiller
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Starting instructions on off switch only labeled O and -
O and I are the international symbols for off and on. The O is the off position and the I is the on position. Put the switch in the I position. Make sure there is properly mixed fuel in the tank. Your Mantis probably uses fuel mixed 1 part 2cycle oil to 50 parts gasoline. Push the primer bulb a few times until you see fuel in the bulb. Position the choke lever to full choke, open the throttle completely and use short, quick pulls on the rope until the engine sputters. Reposition to choke to half and pull the rope again. The engine should start at this time. Let the engine run for a few seconds, then push the choke lever to off. Go to work in the garden.
Aug 24, 2010 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
2003 HD Low Rider. Went to crank and gas+oil
sounds like stuck needle valve if it's carbureted,letting the gas run into the engine filling it up,has to go somewhere if its full,you need to drain it out,don't try to start it,with all that gas in the oil it will not get proper lubrication resulting in engine damage.Shut off the fuel valve or it will continue to run into the engine.Hope this helps
Apr 05, 2010 | 2000 Harley Davidson FXDL Dyna Low Rider
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Oil smoke on my mantis tiller
Too much oil in the fuel mix. Look for a 2 cycle oil called Opti-2. Comes in 1 or 2 1/2 gallon mix pouches w/fuel stabilizer. One mix for all 2 cycle. It's the best and no measuring, foolproof.
Jun 07, 2009 | Mantis Tiller
Mantis 2-Cycle Tiller Logo
589 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
