Question about APC BE325 SURGE PROTECTOR + BATTERY BACK-UP (APNBE325) UPS System
Installed battery incorrect then replace but battery+surge protector not working
Model BE 500R
pravinbhavsa
  • 348 Answers
SOURCE: Surge protectors
No no need to charge there may loose contact between power cord and surge protecter or internal loose contact between sockets that can be removed
Posted on Nov 12, 2008
After a four day power outage, my APC BE325R buzzes continuously when started, even though nothing is plugged into it. Has the battery suddenly died, or does it require recharging? Its a very loud buzz -...
It is probably a bad battery. They usually don't last much longer than 2-3 years. You could try replacing the battery, but I would suggest just replacing the whole UPS with a new model.
Sep 08, 2011 | APC BE325 SURGE PROTECTOR + BATTERY...
My Trip Lite Internet550SER UPS battery back up /serge protector was purchased through Dell only 8 months ago. Last night we had a major strom with power outage. This morning when I came in the devise was...
Yes, it can. I have replaced more than a couple of poorly made Chinese gel-cells after fairly brief service.
Also, you can extend your UPS's service time before the battery is depleted by turning off the monitor and settings the Power Management settings to power-down hard drives after 10-20 minutes.
In my experience, the ratings on UPS systems is wildly optimistic regarding their backup capabilities.
Also; the protection against lines surges caused by even distant lightning strikes is fairly minimal.
If this is in your home, you might consider installing a 'whole house' surge arrester. Depending on the maker, they offer up to $10,000 in damage insurance to cover any losses not prevented by their devices.
The plug-in strips with 'surge protection' have a 50 cent component in them to clamp spikes to ~200VAC and these even get tired with repeated surges and eventually become totally ineffective.
If the battery checks out OK, the circuitry responsible for switching from AC line to backup mode may have already been damaged during the storm.
Switching to the 'surge protector' mode really only provides mildly conditioned AC line and involves no active electronics.
Aug 06, 2010 | IBM Tripp Lite Internet Office 500...
Dynex Te685avr backup battery doesnt work
The sealed batteries in these last about 6 years. You are correct in thinking that you may need a new one. Very easy to install. Here's a supplier of these: http://www.batteryinternational.com/dynex-te685avr-ups-battery-ups-batteries-f1.html
Jun 02, 2009 | Dynex (TE685AVR) UPS System
Surge protectors
Nov 12, 2008 | APC Back-UPS Office 500VA (BF500) UPS...
Reseting my surge protector
What is the model of your battery back up? When does it beep? What kind of beeps?
Nov 02, 2008 | CyberPower 575SL (CPS575SL) UPS System
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
The model of the battery is a WKA12-7.5F2 and can be purchased at: http://www.replacementupsbattery.com/Product_pages/wka12-75f2.html.
Jun 26, 2008 | Dynex (TE685AVR) UPS System
Transformer
Several things have happened. 1st have you tried plugging the monitor in the wall and not in the surge protector. 2nd does your power button or LED light uo when you power it on? You have stated the transformer is bad due to lighting strike. Have you replaced the transformer? Your monitor should be coverd under the surge protector warranty. Please answer questions and we will go from there.
Jan 03, 2008 | Computers & Internet
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
Nov 18, 2007 | Cybernet Systems CyberPower 625AVR...
CyberPower 325SL backup system
How old is the unit and have you ever replaced the batteries?
Sep 14, 2007 | CyberPower 325SL (CPS325SL) UPS System
CyberPower 325SL won't work...
NEVER mix surge protectors and UPS!!!. Doing so overloads whoever of the two gets connected to the wall. This equipment is built to be plugged DIRECTLY to the wall. Your unit just crossed it's inner battery. Take it to a recycling center, then stop on your favorite electronis shop and buy a new one.
Computers & Internet Logo
23 people viewed this question
Top APC Computers & Internet Experts
Shawn DuRee
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
