Question about Panasonic Lumix DMC-FX7 Digital Camera
Lumix DMC-FX7 No Controls issue
Hi Sakell -
Had posted this question yesterday on the thread, but thought I'd ask direct.
Controls have frozen up on my Lumix DMC-FX7 camera, and your idea about the zoom switch being at fault seems plausible...any suggestions on how to clean it out? Mine is not stuck, just no control function of any type, and zoom indicator is shown on LCD window (as also described on similar problem from other user).
    Top Expert:
  • Panasonic Master
  • 85,161 Answers
The cheapest thing to do here is just replace the camera, they are not fixed just exchanged by the factory.
Posted on Jul 06, 2017
SOURCE:
SOURCE: Panasonic Lumix DMC-FX7 software download
It's easier to download pictures using card readers. Just insert the SD card in the reader and plug it in you computer. Double click the folder DMIC and you can drag and drop the pictures.
You can buy card readers in any computer store for $5-$10.
Posted on May 23, 2008
  • 11967 Answers
SOURCE: Lumix DMC-FX01 Buttons not working
Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
Posted on Aug 23, 2009
  • 16 Answers
SOURCE: panasonic lumix dmc fz18 won't zoom in or out
The innards of modern DSLRs are precise and fragile. You need to contact a reputable repair shop ASAP. In addition to fixing your camera, they will clean the interior properly, eliminating dust particles that find their way to the CCD. The cleaning is something you should have done from time to time anyway, so just bite the bullet and take it in!
Posted on Sep 05, 2009
  • 18 Answers
SOURCE: panasonic lumix dmc-fx37. Two error messages are
sounds like the focus and (Optical Image Stabilization)drive motors are bound or broken, sadly this normaly means new camera, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well ya know, they will normaly repair or replace it as long as it is due to manufacture defect.
Posted on Mar 16, 2010
Testimonial: "thanks for your help. "
lock123
  • 6831 Answers
SOURCE: system error (zoom) camera frozen Panasonic Lumix DMC-LZ28
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Oct 07, 2010
I Keep getting message on camera screen that the card is not formatted.How do i format it?
The Format command is in the Playback menu.
The DMC-FX7 uses MMC and SD cards, 2GB or smaller. Make sure you're not using a higher-capacity SDHC card.
Aug 15, 2013 | Panasonic Lumix DMC-FX7 Digital Camera
The lens on my panasonic lumix dmc-fx07k camera will not open or extend out. when you turn the camera on it sounds as if it is in the process of opening and coming out, but it does not.
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Panasonic Lumix DMC-FX7 Digital Camera
I need to order new parts for my Panasonic Lumix DMC-FX7 Digital Camera but dont know where to buy the parts or find part numbers
You can order the parts on the manufacturer's support website by clicking this link.
On the page which opens, enter the model number in the box under "Search by Model" section and click on "List Parts by Model" button. The complete list of parts and accessories will open and you can place an order for the parts you require.
Hope this solves your problem. Thanks for using FixYa.
Apr 08, 2010 | Panasonic Lumix DMC-FX7 Digital Camera
No sound in recording videos
Do you mean in your camera or on your computer. If on your computer Google K-Lite. Hear you can download the codec drivers to update your computer to view and hear the movies you record.
Jul 02, 2009 | Panasonic Lumix DMC-FX7 Digital Camera
May 22, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Help my camera will not take pictures
you more than likely have a lens fault, on playback mode you can view the pictures but on camera mode you cant take pictures.
Feb 08, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Jan 19, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Poblem with my panasonic lumix dmc-fx7
It may that your battery has lost its charge, or has leaked? If it won't hold a charge try taking it out wiping it and trying again if that doesn't work you may need a new battery.
Lumix dmc fx7 broke lcd
Many panasonic fx7-9 are suffering the same problem, unexplained breakage of the LCD, Panason ic have admmited this may be a manufacturing fault, try your agent for free replacement
Sep 02, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
Panasonic Lumix DMC-FX7 Digital Camera Logo
77 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
