Question about Philips GOGEAR SA6045 MP3 Player
SA6045/37 is dead
My SA6045/37 is dead dead dead. When I plug it into the computer it flashes the blue Philips screen off and on for about a minute then nothing. I have tried to repair it but the computer doesn't recognize it. I thought maybe it was just that the battery was dead because I haven't used it in about 2 months but I can't even charge it (on the computer or in the wall).
Any suggestions besides to throw it in the trash (which is what I am about to do)?
  • 1 more comment
  • martha0315 Oct 09, 2008
    my MP3 Player wont turn on or charge the screen just blinks
  • martha0315 Oct 12, 2008
    i have the same problem with my sa6045 philips mp3 player, its dead, and when i try to charge it with the computer, or plugging it into the wall, all it does is blink for about a minute, and then nothing.
  • Anonymous Nov 15, 2008
    just flashing
Jjh
Posted on Oct 10, 2008
SOURCE:
Single blue light flash then nothing
your computer power supply or motherboard is dead. I'd bring it in to a computer store for repairs/parts replacement. (if it's not under warranty, of course).
Jan 22, 2014 | Dell Vostro 420 Desktop Computer
Wont turn on
Hello, It looks like a dead hard drive... To check your hard drive and see if you can repair it yourself, reboot your computer press simultaneously the "cmd" and "s" keys at startup if you see a black screen with white text, type: fsck -f and hit enter this does a "file system check", when finnished, type "reboot" and press enter. If nothing better happens, you'll certainly have to brinng it to an Apple Authorized Center Best regards
Jun 10, 2009 | Apple MacBook Air
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
Power button just flashes will no turn off AND nothing on the screen
On back of the computer is a on off switch for the power supply, or unplug the computer for one minute. Turn the switch back on, or plug the computer back in and try to turn it on.
Apr 20, 2009 | Computers & Internet
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Can't charge, computer doesn't recognize
Make sure the hold/lock switch is not engaged - see manual for details. Probably needs to be replaced - that is a sure sign of a hardware issue, and it is not something that can just be repaired. but, just to be safe, try this:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 10, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips GOGEAR SA6045 MP3 Player Logo
267 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
