Question about Dacor EHD3618SS Kitchen Hood
CAN'T GET LIGHT BULB OUT
I CAN,T GET THE LIGHT BULB OUT OF MY DECOR KITCHEN HOOD.
MODEL # EHD3009SCH
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
K44.z.902.300
Were you able to find a place to buy extra knobs for this range hood ? can you let me know ? sam@rossrealtors.com November 20, 2017
Jan 29, 2013 | Rangemaster Kitchen Hood
Burned out light on bertazzoni hood
Here is how I fix this problem in case someon is still looking for an answer: 1. Turn power to hood off at electric panel 2. Remove light diffusers - these are the round glasses under hood covering the light bulbs. Turn the light diffuser counter clock wise to remove 3. Remove the burned out light bulbs 4. Install the new light bulbs
Jan 05, 2012 | Bertazzoni K48HERX 48" Kitchen Hood
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
I have Sakura kitchen range hood model #c R706, R727 and Want to know how ro chaneg teh bulb. Thanks
I found all the part I needed for my Sakura range hood at http://www.rangehoodking.com/ they had everything I needed. of cos that light bulb too!
Dec 31, 2010 | Kitchen Ranges
Removing existing light bulb to replace.Flush mount with nothing to grab on to
Use rubber kitchen glove to grasp bulb. Be careful not to cut yourself if bulb breaks.
Jul 07, 2009 | Zephyr Pyramid ZPY-E30 Kitchen Hood
Dimmer light won't work.
you are using incandescent bulbs because most dimmer will not work with Fluorescent otherwise sound like a bad switch, if it new return it. They are fairly easy to replace. Hope this Helps Paul
Jun 17, 2009 | Kenmore 51840 Kitchen Hood
Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Jul 23, 2008 | Kitchen Ranges
Light doesn't work on Kenmore Model 55022 Range hood...
If you have 120VAC on the center contact of the light socket, and a working fan, but the bulb won't light...the most likely cause would be a disconnected neutral wire (white) in the light wiring inside the hood....assuming everything else is wired correctly.
If you're comfortable with further electrical testing...let me know, and I can describe a detailed procedure to check the status of the neutral wire. Otherwise, you may need the assistance of someone familiar with electrical troubleshooting or appliance repair.
Jan 27, 2008 | Kenmore 51840 Kitchen Hood
Dacor EHD3618SS Kitchen Hood Logo
76 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
