Question about Canon Office Equipment & Supplies
We have a MF6550 copier and fax machine. sometimes it doesn't pick up the paper and therefor we get no faxes. Other times it will say processing memory and get stuck there until we turn off the machine and restarte it.
  • 76 Answers
8/10 its normally due to the Pick up Roller, There should be a arm and a Spring which allows the rollers to spring back. Turn the machine on its back and see if they are there? This will always cause it to jam and the roller will not return.
Hope this helps
Posted on Oct 18, 2008
I have faxs stored in the memory but do not know how to print them?
It should print by itself unless you have an error message (Low Toner, or Incorrect Paper Format or no more paper) and your Cont. Printing setting is set to OFF. To set it to ON, go in your Fax Settings, then Printer Settings, then Cont. Printing. This works on my MF4150, hopefully this will also work on its older brother MF6550... Just check your user manual (if you lost it, check canon's website).
Nov 20, 2009 | Canon imageCLASS® MF6550 All-In-One Laser...
Wont pick up, just rings & rings.
There are multiple reception modes that a fax machine can be in. The default mode is "Auto" and should answer automatically after a predetermined amount of rings. It has probably been switched to "Manual" mode by accident and therefore rings and never picks up. Look for a Reception Mode or RCV Mode button on the machine and press it until the proper mode is established.
Nov 13, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Incoming faxes not received, all else works.
It is your phone answering machine that must pick up in three rings or less.
Therefore 4 is too much. I would not limit number for fax machine itself.
On receipt of fax sometimes seems like it will not work when answering machine picks up in the middle. However, leave it and it will work. Sometimes sender will hear your answering machine and cancel as well. So try to ensure they don't give up at other end as well.
Good Luck!
Feb 26, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Canon will not receive faxes or copy documents
see if you have fax line(conect a telefone in the line to see if you have tone) or if the cable is conected.
Nov 21, 2008 | Canon NP 7130 Black and White Copier
No filter
There you go. Stop by Radio Shack and pick up a DSL filter and hook it up to the wall outlet of your fax machine. If the DSL modem is next to your fax machine, plug the fax machine into the outlet marked as phone.
I just got done doing this to both of my offices. Typically the phone company will use your fax line to piggyback the DSL. All you have to do is make sure your DSL modem output goes to the fax line either through the wiring block in your office or directly to the back of the modem itself.
That way you won't need the filter.
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Multiple fax copies only 1 or 2 get through
First check to see if all 5 are bing sent. Sometimes paper sticks to each other and you may only see 1 or 2. Also your telphone line has a lot to do with it. If you are using a digital telephone line with your internet line such as a vontage telephone, the signal is takene from your internet line for your telephone and sometimes such as when you are on the internet and trying to fax, you do not have enough signal strength. sometimes sutting off the internet works. Also what does the report say from your copier/fax are 5 pages being sent. In the set up this Canon you can get a report after you send a fax....
Jul 09, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
old marine
old marine
Corne Viljoen
