Question about Sewing Machines
Will not zigzag
I had my Singer 2808 sewing machine serviced some time ago. I didn't use it for a long time after that but yesterday when I tried to zigzag I realized that it won't zigzag anymore. It is forming a straight uneven stitch for every zigzag stitch I select. Actually, the needle is moving from side to side correctly but it is not picking up the thread from below. Now even the service guy refuses to accept it as his fault as a long time has passed. Would really appreciate some advice...
  • Anonymous Mar 21, 2014
    zigzag stitch not working---not picking up the second stitch
Have the hook timing checked on your machine.
Posted on Oct 10, 2008
To adjust the singer 500 rocket sewing machine ....adjusting the width .... the swing of the zigzag.....
I am attaching two links for manuals in case you don't have them, an instructional manual and a service (repair manual). The Singer 500 and 500A are the same machine.
Singer 500 Owners manual
Singer 500 503 Service Manual
Jul 30, 2017 | Singer Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
Not stitch zigzag
Have you tried a needle change? It could be blunt or the wrong size. Have you cleaned under the needle plate as the ridges get full of lint there. A toothpick will clean them out.
Nov 22, 2013 | Singer 1120 Mechanical Sewing Machine
Error Code E7 on Singer 6180
E7 means the machine has 'had enough' and that error flashes to let you know it needs a break. I found that out by trial and error and after phoning Singer as well.
Nov 04, 2012 | Singer 7258 Sewing Machine
Singer stylist 7258, will only pick up bobbin on one side when doing zigzag stitch
try using a washable stablizer or interfacing.
if that doesn't help then it's possible that a gear or cam may be worn enough to cause the machine zig zag not to work properly
Mar 27, 2012 | Singer 7258 Sewing Machine
Singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Oct 01, 2009 | Singer 5050 Mechanical Sewing Machine
Machine will not zigzag
The guy is right, dust kills the moving parts. try oiling the shaft that holds the needle up about 1/2 way and then run on straight stitch with no thread to work in oil, do this several times till you feel that it runs smoothly and you have a little movement side to side as this is necessary for your zig-zag. if that does not work it may be a cam or belt in the top part that needs replacing and you will need the repair to tell you that. I asked them to give me a quote before any work was done so I knew what I was up against. I love my machine so it was worth the 200.00 to get the parts replaced. It will sew anything cause it is a older model with metal rather than plastic parts. hope this helps good luck
Jun 17, 2017 | Singer 3116 Simple
Singer 5050 won't zigzag stitch
I have this same issue with that same machine. Did you ever figure out what was wrong with it??
May 08, 2008 | Singer 5050 Mechanical Sewing Machine
Sewing Machines Logo
432 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
