Question about Teac Audio Players & Recorders
Turntable won't turn - Teac Audio Players & Recorders
    Scholar:
  • 47 Answers
Hi!
Without any other information (and assuming you've checked to make sure there is power to the turntable and that it is turned on), the likely culprit is the belt drive of your turntable. Most, but not all, turntables have a "belt" that looks like a big rubber band on the underside of the turntable that connects the turntable itself to the drive motor. If the band has slipped out of place, stretched too far from age or usage, or broken, the turntable won't turn. To find out if this is your problem, gently lift the "platter" straight up (it should easily slide back into place) and visually see if the "rubber band" is in place. If it is stretched too far or broken, a new one should be availble form Teac or your local electronics supplier. If, by chance, you have a direct-drive turntable (unlikely), the problem will probably need professional work.
Good luck and please let me know if this helps!
Bob
Posted on Oct 09, 2008
I am trying to play a record on my Aiwa LX-120 turntable but after scanning the record the arm won`t go down.
I'm not certain that you are meant to disengage the FG lock since this means that the turntable has achieved the correct speed. The problem you have is that the arm won't go down.
I don't know to much about the workings of this direct drive turntable. But I can say you can get the service manual free on-line if that helps.
May 01, 2015 | Aiwa Audio Players & Recorders
Locked won t turn
The belt has stretched from age.
Jan 03, 2014 | Technics Audio Players & Recorders
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
Goldstar under counter microwave spindle won't turn
use the common sense, and logically, fix it. God bless you
Microwave Runs, Heats, but turntable does not move This is a fairly easy one. First, make sure the turntable coupler under the glass dish is not broken. Second, on the control board, find the turntable relay and test for voltage. Some turntable motors are 24 volts DC, so make sure your testing the correct voltage. If no voltage from the control board, then replace the control board. Otherwise head towards the turntable motor.
On OTR models, you can get to the motor by un-screwing the bottom panel on the microwave. On countertop models, there will either be a knockout or screw on access panel. Check for voltage at the motor. If no voltage, check the wiring back towards the control. If voltage, then replace the turntable motor. The component list below also shows how to test a turntable motor.
Aug 02, 2012 | GE Microwave Ovens
Microwave turntable won't turn.
Return the item to the place of purchase this is a manufacture defect. The problem is caused by a defective turntable motor.
May 20, 2012 | Hamilton Beach Microwave Ovens
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
My turntable won't spin - the spindle is fine and it makes half hearted efforts to move but will only **** a few times and then stop.
The self-lubricating bushing in the turn-table is dried out. This is a difficult problem to solve and best left to an expert. Don't expect great results.
Sep 06, 2011 | Stanton ST-150 Turntable
222 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
