Question about Dell Dimension 2400 PC Desktop
Video out on dimension 2400
I am trying to hook a dell dimension 2400 up to my 42" lcd and it seems like the video out on the back of the computer is not sending a signal. I have a yellow RCA hooked to it and even tried hooking the current monitor (hooked to the top monitor port works) to the output next to it and that didnt work either. the only one i havent tried is the s-video out. I need either s-vid or rca to work so i can line in audio on same channel on the tv.
  • 21 Answers
    Master:
  • 538 Answers
All of those are controlled by the video card-software management panel..go to dell support website, and make certain you have that latest driver set..then you should be able to enable any of those options.
Posted on Oct 09, 2008
    Champion:
  • 208 Answers
Uhh dimension 2400 doesnt have rca yellow out or agp. only pci ports.. sounds like u installed a tv tunner and it has a yellow rca INput. not out.
Posted on Oct 10, 2008
I have a Dell Dimension 2400 desktop. It needs a monitor. I tried new ones from Best Buy and Office Max but they say no signal when I hook them up..I tried this computer with monitor in the following
Thank you for replying,
As per the diagnostic LED's, it is an issue with Video initialization failure. Your computer has onboard Graphics which is built into the Motherboard.
Video Initialization failure could happen if there is :
Unseated AGP card
Bad AGP card
Bad motherboard
As per your Svc Tag your system doesn't have AGP Graphics Card, Probable issue with MOBO.
This computer doesn't have a AGP Slot (Graphics Card Slot) to try connecting Graphics Card.
Need to repair/replace MOBO.
Thanks.
Feb 25, 2014 | Dell Dimension Computers & Internet
I have a dell 2400 desktop computer. I recently got FIOS and they hooked my wife's computer to their router with an ethernet cable. Can I also hook my dell up the same way?
Depends on the hardware. Is it a router or modem? Does is have extra ports in the back,
Router with extra ports, just connect new device with wire or even wireless if it has wireless.
Modem, most likey you have to buy a router.
Dec 28, 2012 | Dell Dimension 2400 PC Desktop
How to remove computer cover
Try this website..this is a manual for Dell Dimension 2400 PC Desktop
it includes how to remove the cover of your tower. Check it out..
http://www.andovercg.com/datasheets/dell-dimension-2400-series.pdf
Sep 14, 2010 | Dell Dimension 2400 PC Desktop
I have a 7 yr old Dell Dimension 2400 with a 17" Dell E171FPB flat panel monitor. Frequently, but not always, the monitor will flicker on/off every few seconds then go black for several minutes. It has...
Find somebody with an old CRT-style monitor -- they are essentially WORTHLESS -- because they take up too much space, and not as nice a picture as an LCD, and offer to take it off their hands. Use it as a "test" monitor.
Or, it could be the video-card in your SEVEN-year-old computer.
Try replacing the video-card -- some friend probably has a "dusty" and "spare" video-card that can be temporarily used.
Jul 30, 2010 | Dell Dimension 2400 PC Desktop
Put in new memory in a dell 2400 now front
make sure all cables are properly seated inside the case. just the d light being yellow and no other means some other failure occured,
Feb 20, 2010 | Dell Dimension 2400 PC Desktop
Dell 2400 Serial Port won't work with seperate video card
you have to disable the video card so you can use the on board
Jan 17, 2010 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 Powers Up But Doesnt Show Up On Monitor
Seems your new RAM was not compatible but it shouldn't have caused a problem.
Use your original RAM - Is it one stick or two? Take one of your original RAM sticks (or the original one if only one) and seat it in a slot - test it. Move it to next slot - test it etc.
Aug 29, 2009 | Dell Dimension 2400 PC Desktop
LOST PICTURE ON FLAT SCREEN
If you buy new PCI video card there is alway CD software attached on this,you should claim for this because it was the driver for your new video card ,without it your PC will have an abrormal operation .Are you sure it was your video card?you can consider also your memory card,Wiht out hardisk,CD room,floopy your computer will run it can open your monitor configuring the cmos and bios.Try on this one disconnect hardisk,cd room,floopy then detouched your memory card clean using pencil eraser the sloted terminal of your memory card,also your video card try to clean terminal by pencil eraser.Then put back memory and video card again if the monitor work.If ok put back again the cdroom,hardisk, and floopy.If not ok Isolate checking the memory and video card also the processor.
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
419 people viewed this question
Alun Cox
