Question about Cameras
CanonA75 Loose ribbon
How does one fix the loose ribbon??
  • 48 Answers
The ribbon is lock in place with a bar that will rotate up or down. With the bar up lay the ribbon in place and push the locking bar down to firmly hold the ribbon in place
Posted on Oct 15, 2008
How do you stop the print cartridge and correction from coming loose when you use it?
If you are having trouble with the ribbon itself getting loose I have found that many generic ribbons don't hold proper tension.
If you mean that the cartridges are coming loose sometimes the blue latch that holds it down breakes.
Jul 13, 2014 | Lexmark Office Equipment & Supplies
How to fix display on Dterm80
Ribbon cable inside phone to display sometimes gets jarred loose. If you can remove the base, then unscrew the 2 screws holding the display in place, then slide it out and look for the ribbon cable being loose. If you have small hands maybe you can get that back to its spot. Better yet buy a replacement phone on eBay for 25 bucks instead of hoping it'll go back in and work properly. Some displays go bad line by line, in which case there's no help for it.
Jun 03, 2014 | NEC Dterm DTP 16D-1 Corded Phone
Maytag Epic has a damaged wire harness connection to the touchpad assembly.
To prevent any other new electrical problems, it would be better to buy a new ribbon cable.
May 16, 2014 | Washing Machines
After changing the ribbon, i am unable to print labeles because of a "ribbon error" and i don't know how to fix it.
Remove the ribbon, ensure that it is not loose and refit - I have had this before - the ribbon has basically not slotted down properly when inserted.
Oct 04, 2013 | Office Equipment & Supplies
My nintendo ds top screen is white
it might be that the ribbon cable connecting the top screen with the bottom screen is loose. you can open it and fix it by yourself, if you want. if it doesn't fix the problem, is either the screen or the ribbon cable that needs replacement.
Jan 05, 2010 | Nintendo DS Console
Ribbon does not move during typing and no ink gets on paper.
It appears that the ribbon feed connector has come loose from the ribbon feed motor. On top where the ribbon sits you will see where the ribbon couples to the ribbon feed motor on the right side. Look on the bottom of the ribbon and you will see where the ribbon couples with the ribbon deck feed motor. Directly under that ribbon deck is the ribbon feed motor. It sound like the cable came loose and it just needs to be plugged back into to motor.
Good Luck
Mar 11, 2009 | IBM Wheelwriter 30 Typewriter
Lexmark x8350
In the back of the printer is an access panel with one screw to hold it in place.
The outer side edges are held in place with it plastic tabs (which you can not see due to they are inside the printer. So carefully remove this panel without breaking the tabs. Look inside and you will see a ribbon connecting to a circuit board. This is probably loose or disconnected. The end of the ribbon is hard and not flexible. Push the end of this ribbon in the white plastic standoff slot. This ribbon sometimes comes loose when the top scanner cover is partially remove from the printer. I said, partially because if you needed to remove the top scanner completely, then this ribbon would need to be completely disconnected. You can also see, when the access panel is off, other wire connections connected to this circuit panel. Sometimes they also come loose or disconnect when the top scanner is partially remove. Connect them if they are loose or disconnected. I believe to solve your problem is the ribbon disconnected. Best wishes in solving your problem.
Sep 28, 2008 | Lexmark X8350 All-In-One InkJet Printer
Camara lg
hey sounds like the camera ribbon has broke or come loose take it apart and check for little marks on the ribbon.
Jul 31, 2008 | LG KU990 Viewty
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
