Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa c250 frozen
The sansa c250 was partually submerged in water the micro SD solt, and the charging cable slot were submerged. NOw when i charge it it is stuck on record, however it can sync files to it
I had the same problem and solved it by repeatedly blowing real hard into the slots. Eventually a couple of drops of water came out and everything worked again.
Posted on Oct 19, 2008
  • SanDisk Master
  • 1,800 Answers
Try to dry it using a brush and medical alcohol and a hair dryer and check if it would give u result
Posted on Oct 09, 2008
I dont know how to charge my mp3 player and its dead
Plug one end of the supplied cable into the slot in the bottom of the Sansa. Plug the other end into a USB port of a computer. Make sure the computer is turned on, and it should start charging.
Mar 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa express 1gb does not working
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work to reset it. To charge it in a pc, just plug it up and it should come up. Then in a few seconds, it should start charging.
Aug 04, 2009 | SanDisk Sansa MP3 Player
Sandisk Sansa C250 won't recognize 8Gig micro chip
Your model doesn't natively support SD cards over 4GB, however I hear you can install something called "Rockbox," it's a free third party firmware that allows you to dual boot between "Rockbox" and the Sansa firmware. "Rockbox" adds the support you need for SD cards with a capacity of 4GB or more. I've never used this firmware, but it does sound promising.
Download it here
Sorry I couldn't be more help.
Jun 03, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
How do I use the SanDisk adaptor and the SanDisk 2GB microSD
The micro card (the smaller one) can be used alone in a port that accepts (microSD ports)such as those on a Sansa c240, c250, e250 etc.
If you have a regular SD slot (larger than microSD) then you plug the micro card in the adapter and plug the whole into a regular SD slot.
Plug the card in your computer and copy paste the files. Or plug the micro card in an MP3 player that accepts it and use you music transfert software.
You only have one card (the micro SD one), which you can use in two possible slots.
Hope it helps.
May 19, 2009 | SanDisk 2GB microSD Memory Card
Ghost Files
I would run the Sansa Recovery Tool for the c200 series - it will erase/format all the songs without deleting system files - it is available from Sandisk's website.
-Tha Mp3 Doctor
Dec 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
How to use memory card in sansa c250
This player only RELIABLY reads SD cards that are 256 MB or smaller - anything else is a crapshoot
May 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 Micro SD card not recocnised
You need to create a folder named MUSIC on the MicroSD card to copy your MP3 files into
Mar 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa c250 sd card installation
yes i have the same problem how do i get the music onto card itself
Jan 10, 2008 | Audio Players & Recorders
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
87 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
