Have a Samsung HL-P5063W Projection TV - HDTV - The hi-def does not work, but don't care about that. TV is 3 years old. All of sudden, it will just shut itself off after running for about an hour. Any ideas what the problem is and is it something I can repair?
    Master:
  • 538 Answers
Perhaps...that is usually a thermal issue, caused by a malfunctioning component on the control board..how handy are you with tearing apart something of this scale, and digging down into the circuit board..takes a special kind of soldering iron too
Posted on Oct 09, 2008
    Guru:
  • 1,894 Answers
Can you let us know the blink code
if it is 3 then you will have to replace the lamp
  • 1 more comment
  • dewan nafees ahmed Oct 09, 2008
    it can be either
    • DMD PCB and the DMD IC
    • ballast
    • lamp
    it can any one of these. it may even extend. if you let us know the blink code it will be highly useful for us to solve your problem
    thank you
    DMD PCB will be around $500 , DMD IC will be around $270
    the ballast will be $70
    http://www.fixya.com/support/r153305-dlp...
The picture come on then goes black and then the television turns off. I thought it might be a bulb problem (4 years old). So I bought a new bulb, seemed to work and then began to go black again with all 3...
when the colorwheels start to go bad this is the symtom that shows up. try this listen carefully to the rear of the tv near the lamp door. as you turn off the tv if you hear a slight grinding noise as the colorwheel slows down that means the bearings inside the colorwheel are dry and you will need to replace the colorwheel.
Mar 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung HL-P5063W set turns off on its own randomly. Set is 5 years old. This started after I went on the AT&T Uverse service, but that may be coincidental. The Uverse box and service stay on, but...
First thing change the lamp. There are several other things but this is most common. Be sure tab on lamp door presses door switch in downward position when you change the lamp. MCM Electronics you can get a philips bulb for $99.00.
Nov 29, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Only black and white
The same thing happened to my HLP5063W. Researching the internet forums I concluded the problem was with the color wheel, which I replaced. As it turns out the old one was completely smashed. Go to www.jangro.com for replacement instructions.
Jul 05, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Problem turning On
Same exact problem started 01-08. Any suggestions yet>?
Dec 07, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
